Old 08-12-2013, 09:01 PM   #15
ayau
Drives: Some rust bucket
Originally Posted by barabia View Post
How long would you suggest that I let the springs settle?
And do you have any suggestions for camber and toe settings? (daily driver/ HPDE use only)
Some spirited driving should help shift the weight and settle all four corners of the car.
Old 08-12-2013, 09:06 PM   #16
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
for normal driving id say about a day or two at most. With spirited driving it'll be shorter of course. I dont really know how much camber these cars get in the front, but with my old STi i was around -2 Front and -2.5 rear. Im hoping to get around -1.5 Front and -2 Rear without coils, or upgraded lca's etc with this car.
bkblitzed is offline   Reply With Quote
Old 08-12-2013, 10:10 PM   #17
barabia
barabia's Avatar
Ok, so I have decided then I will install the springs as well as front camber bolts and adjustable LCAs. Then wait two days, and have the car aligned back to a front camber of -1.2 and the rear adjusted to -1.7 and front and rear toe set to 0". Hows that sound?
barabia is offline   Reply With Quote
Old 08-13-2013, 02:09 PM   #18
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Sounds reasonable
Old 08-13-2013, 05:22 PM   #19
bakerr6
Drives: 2013 raven black fr-s
What LCAs are you going with? I was waiting on the LCAs from whiteline forever, but decided to go with Racer X LCAs instead (should be here later today). They are a little more expensive than some of the options out there right now, but they look like a great design.
bakerr6 is offline   Reply With Quote
Old 08-13-2013, 06:58 PM   #20
barabia
barabia's Avatar
In the end I have decided these springs are not for me :o/ Kind of late in the going I know but I am just not comfortable with altering the suspension in this way, especially because Im afraid its going to upset the balance of the car too much on the race track...aka Im wussing out. Plus, i did not realize i would be investing another $600+ into getting the setup right. (camber bits, install, alignmet, ect.)
Too bad I already bought the darn things! Anybody want to buy? $200+shipping, new unboxed. is it ok that I post that here or should I post it somewhere else?
Old 08-14-2013, 03:00 PM   #21
timerbob
Drives: 2013 FRS Argento
Giving up when the going gets tough? If you ever plan on lowering your car it should be done correctly. Installation, I'm sure someone can help you with that and get it done cheaper than going to a shop. Alignment is almost automatic if you're going lower but it also depends how low. Camber kits, aren't something you need done right away but it seems as though you're afraid to compromise the integrity of your suspension set up. Anyways, don't just give in because you found out there's a domino effect in modding. Nobody says it'll be cheap, unless you want it done wrong.
timerbob is offline   Reply With Quote
Old 08-14-2013, 07:47 PM   #22
barabia
barabia's Avatar
I really wasn't aware that I needed to buy more suspension components to achieve the correct alignment after installation. Its more money than I wanted to spend at this point and Ive just decided Im not that that interested in lowering my car anyway. I agree with you 100% and I think if I do ever want to do it right I would just go with a full coil over package. But because this car will be daily driven 99% of the time, I dont see it as being practical. I just want to have fun on the track when the opportunity to do so is there. So my build goes as follows: slotted rotors, project mu ht+800 pads, motul brake fluid, steel brake lines, tanabe sustech sway bars and strut bars, Michelin pilot super sport tires. Those are to most cost effective/practical upgrades that I have found. In the end the springs just dont quite fit the build for me.
Old 08-14-2013, 07:58 PM   #23
barabia
barabia's Avatar
Btw thank you everyone for your help on the matter. If I would have done the due diligence in the first place before ordering I would not have ended up with a set of springs Im not going to use. I appreciate all the valuable input and I know much more now than I did going into this.
Also, as mentions earlier, if anybody is interested in taking advantage of my choice not to install, Eibach Sportlines for sale, unboxed $200+shipping, just message me.
Old 08-14-2013, 08:12 PM   #24
FRS1010
Drives: 2013 FRS
They are a few people that are looking for some in the for sale section. I would take some pics and post them up. Should sell pretty quick at that price! GLWS!
FRS1010 is offline   Reply With Quote
Anyone with Eibach Sportlines gatorbushmen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 12-12-2013 01:55 AM
RCE Yellows or Eibach Sportlines? ChandlerSwyng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-21-2013 04:09 PM
NY: F/S Eibach Sportlines delusional Brakes, Suspension, Chassis 7 04-26-2013 12:35 PM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
