Old 05-30-2013, 05:28 PM   #15
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by kroarke View Post
Just talked to the my service rep about this today. Wanted the red STI filter but apparently they can't get that. You need the black filter. Not the blue one. He made a comment about how the black ones are used on the V6 SUVs and the BRZ. Their other 4 cylinders get the blue one.
Just an FYI Subaru doesn't make any V motors. The filters are the same as the H6 motors found in the Outback, Legacy and Tribeca.
-Mike Paisan
AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor!
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 05-31-2013, 01:54 PM   #16
kroarke
kroarke's Avatar
-Mike Paisan
Hahaha. I don't know why I wrote that. I meant H6 for sure.
kroarke is offline   Reply With Quote
Old 05-31-2013, 01:55 PM   #17
kroarke
kroarke's Avatar
But yea I'm pretty sure it has to do with NA vs FI
Old 05-31-2013, 10:58 PM   #18
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
The 15208AA15A oil filter is made by Honeywell who apparently makes Fram filters as well. Fram filters are generally not highly regarded. The 15208AA130 on the other hand is made by Tokyo Roki in Japan. In my personal and possibly nutty opinion, I would not run anything but the 130. 160 maybe if it came down to it. Maybe I should just buy a pallet of the 130's in case there's ever a shortage.
If you go to parts.com and enter in 15208AA130, it'll return you with a handsome price for what is actually the 15208AA15A filter
Subaruonlineparts.com sells them for $72.43 for a case of 12 with crush rings ($6.04 for 1x oil filter and 1x crush ring) + the cost of shipping.
Answering all the questions that no one asked!
Here's some info I copied from a user on NAZIOC (all credit to him/her).
Tokyo Roki 15208AA160
Specs:
OD: 86.25mm
Length: 70.18mm
Thread: M20x1.5, Roll-formed
Spring type: Stamped leaf
Bypass Valve: 23 PSID, Metal valve integrated into the end cap on the dome end.
Anti Drain Back Valve: Yes, Nitrile
Media type: Paper
Media Surface area: 1,092cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Gasket style: "P" ring
Oil inlet hole/s area: Six 6.25mm holes. 184.07mm2 total area.
End caps: Metal
Can side thickness: .44mm
Honeywell/Subaru 15208AA15A (blue filter)
Specs:
OD: 67.9mm
Length: 86.9mm
Bypass Valve: 23.2 PSID, Plastic, located in the stamped spring, positioned at the end cap on the dome end
Media type: Paper
Media Surface area: 837cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Oil inlet hole/s area: Ten 5mm holes. 196.34mm2.
End caps: Engineered media
Can side thickness: .37mm
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-01-2013, 09:41 AM   #19
BRZnut
Drives: BRZ DGM Limited
Just returned from my Subaru dealer for my first oil change and they used the black filter..15208AA130
Old 06-06-2013, 08:43 PM   #20
Bt216
Bt216's Avatar
Drives: Scion frs
I bought a mobil 1 filter and is smaller.. the original black filer is bigger..is it better?
Bt216 is offline   Reply With Quote
Old 06-07-2013, 02:06 PM   #21
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
So far for what they have told me here in the forum yes the original is better,,, now the question is
Original,,,HKS or Greddy?
kombatlion is offline   Reply With Quote
Old 06-07-2013, 02:22 PM   #22
SkullWorks
Drives: SSM LT MT BRZ
Why do people always want to assume the JDM tuners know more than companies that actually design and engineer products?
At no point should you buy something that has been bought in bulk and rebranded unless you know who made the original, and even then why would you happily pay someone elsr for the courtesy of rebranding aother's product.
HKS GREDDY and the likes DO NOT MAKE OIL FILTERS.....and if they did they would suck. All you are doing is throwing (too much) money at a brand name and getting an unknown product in return, or even if it is a known product from a known manufacturer you are getting taken because you will be paying extra for the box and the sticker...
SkullWorks is offline   Reply With Quote
Old 06-07-2013, 02:41 PM   #23
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Like!!!!
Old 06-07-2013, 02:48 PM   #24
AZP Installs
Well said!
-mike
Old 06-08-2013, 10:35 AM   #25
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
+1 just get the original filter, unless you are doing some car show I can see why you'd want brand name for the look.
Went to buy a filter at the dealership today, they picked up the blue one for me, I just asked for the black 130, easy and fast. He did ask me if I was sure if it'd fit? Well of course it would, car freaking came with it... he exchanged it fast though and noted that he knew what part I was talking about, so I'm pretty sure another BRZ owner asked for the same thing.
Myv is offline   Reply With Quote
Old 06-11-2013, 10:26 AM   #26
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Yeah I got it all sorted out and the 130 filter is back on it. I pointed out the service bulletins they showed me were for a completely different car. SOA also called them again and let them know that there was no change in filter parts for the BRZ.
Needless to say, helped out fellow BRZ owners in the area. I actually like this dealership's service department. They do a good job and fast too.
Old 06-11-2013, 10:33 AM   #27
ft_sjo
Drives: GT86
So which one is SU003-00311?
Old 06-11-2013, 06:17 PM   #28
pitstops
Drives: SC RB FRS
check out this post, its the best oil filter test out there. http://forums.evolutionm.net/evo-eng...63t-4b11t.html
pitstops is offline   Reply With Quote
WTS: Used TRD Air Filter Snowblind Engine, Exhaust, Bolt-Ons 2 05-27-2013 11:20 AM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
Some Pre-Delivery Shenanigans we should all be mindful of... PecanSandies BRZ First-Gen (2012+) — General Topics 42 06-05-2012 01:38 PM
