Old 04-30-2013, 07:47 PM   #15
Kregar
Kregar's Avatar
Drives: 2013 Scion FR-S, Asphalt
Originally Posted by DJCarbine View Post
Stock header?
yup
Kregar is offline   Reply With Quote
Old 04-30-2013, 08:19 PM   #16
Kregar
Kregar's Avatar
Originally i took it too the dealer think it was suspension or steering grind but im guessig since its only started since i put on this over pipe, that has to be the only thing left. I will try wrapping it, i just re torqued all the exhaust bolts and double checked the engine mounts. Thanks for all your help this is for sure one of the better forums ive ever been on!
Old 05-29-2013, 10:17 PM   #17
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
put the car up on jack stands, loosen your exhaust connection at the overpipe/header, then use your jack to lift the front/overpipe up, then retighten.
try to create a 3/8 to 1/2 in gap between the pipe and the subframe. Obviously this will be variable dependent upon the car, but this should solve your issue. It did for me.
killerkid08 is offline   Reply With Quote
Old 05-30-2013, 03:41 PM   #18
chutrain
chutrain's Avatar
Drives: WRB BRZ
I have mine hitting the swaybar. Anyone experiencing this with a thicker swaybar up front?
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 05-30-2013, 03:45 PM   #19
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
So has this been solved? I just received my nameless downpipe with resonator and cat. I am hesitant to install it..
shu5892001 is offline   Reply With Quote
Old 07-11-2013, 01:15 PM   #20
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Having the same issue. Got a FA20 overpipe, and i notice its making slight contact on the sway bar. Not always noticable, but sometimes hitting it. Anyone have issue with this? Fixes?
I was able to push it up a bit, got about a 1/4" betwen the swaybar and pipe. Dented the pipe at that location slightly to allow a bit more room. Prior it was touching the swaybar at rest.
Stock swaybar, but looing to upgrade soon, but would prefer to have the new bar installed without the pipe hitting/rubbing on it.
gdrider77 is offline   Reply With Quote
Old 07-11-2013, 01:20 PM   #21
chutrain
chutrain's Avatar
Drives: WRB BRZ
I was thinking of using a spacer on the swaybar subframe mounts to bring it down just a bit. Only really hear it on first gear takeoffs when slightly more aggressive.
In the garage:
1988 BMW E30 M3
Old 07-23-2013, 10:19 AM   #22
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
I installed the FA20Club overpipe yesterday between my Borla UEL and my HKS front pipe and the overpipe was sitting onto the swaybar. It was totally unacceptable right away when starting the car.
To fix my problem, I modified the bracket that hold my front pipe to the tranny to make the bracket shorter and push the exhasut system higher toward the floor of the car.
It did help, it was now 50% better but I was still hearing bumping noise in some circonstance.
So I had no other choice than using a torch to warm the overpipe and I used a hammer with a punch to create a small bump onto the overpipe to give me the clearance needed.
Problem resolved.
Now I'm having another problem, it look like I've lost a lot of torque.
The car feel lazy below 4500rpm.
I will send a log to Toni may be he can fix that.
Right now I feel like I've spend 300$ to make my car slower.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 07-23-2013, 10:59 AM   #23
wparsons
wparsons's Avatar
Have you given the ECU time to adjust? It might take a few drive cycles to sort itself out.
flickr
Old 07-24-2013, 12:27 AM   #24
NoFear99
NoFear99's Avatar
Well to be honest not that much.
This was my first impression right after the install.
Today my car was feeling pulling better but my ecutek logs showed I was fully rich.
Old 07-24-2013, 02:30 PM   #25
chutrain
chutrain's Avatar
Drives: WRB BRZ
I finally got a chance to get under the car and used some washers to bring the mounts that hold the swaybar down slightly. No issues with hitting now.
In the garage:
1988 BMW E30 M3
Old 07-24-2013, 04:24 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The best way to get clearance when installing over and mid pipes is to leave everything loose and start at the downpipe/header with tightening things. If you need more clearance in an area then get a buddy with a pry bar to stick it in and pry where you need clearance before tightening.
Old 07-26-2013, 06:53 PM   #27
MadModder
Drives: 2013 Toyota 86
I have the Milltek non-catted system with overpipe. When I installed the system I had about 1/3" clearance between the overpipe and swy bar. On cobblestone roads and hard left turns, it rattles.
Tonight I took the car out or it's first track day. Immediately after the first few corners, it began to sound like a jack hammer under my car near the overpipe. I checked it after the first session and tried to readjust it. This helped for about 4 laps and then it came back jut the same.
The odd thing is, driving back home after we finished racing there was NO rattle at all. I have got to find a solution to this. I'm not keen on denting the pipe but I am willing to try modifying the transmission exhaust hanger.
Any other suggestions without shimming the sway bar?
MadModder is offline   Reply With Quote
Old 07-26-2013, 07:16 PM   #28
NoFear99
NoFear99's Avatar
Use a torch to make the overpipe hot hot then use a hammer with a punch to make a small bump where is the contact area to give you the clearance needed.
Problem gone!
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
wtb overpipe hunter3232792 Engine, Exhaust, Bolt-Ons 7 05-12-2013 01:38 AM
Header and Overpipe... Scooby South Engine, Exhaust, Transmission 17 04-06-2013 08:35 AM
Invida N1 ti tip w/ overpipe Evilbrz151 Engine, Exhaust, Bolt-Ons 4 03-29-2013 09:34 PM
overpipe? ft86me Engine, Exhaust, Transmission 19 03-28-2013 09:57 AM
