Old 04-07-2013, 11:45 AM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by Vracer111 View Post
securing the lug nuts in sequence by hand before tightening and torquing is what properly centers the wheel.
No, thats what the CENTERING rings are for, they are on both my track and non track wheels
Huehuecoyotl is offline   Reply With Quote
Old 04-07-2013, 11:49 AM   #16
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The wheel will still be centered without hub rungs. I've run several hundred thousand miles without them on my old cars and my wheels were always centered.
Just a pain in the ass to take on and off because that car had lug bolts, not lug nuts.
I've run both with and without them at the track.
Old 04-07-2013, 11:56 AM   #17
Huehuecoyotl
we'll have to agree to disagree here, respectfully
I run a truck that I converted from hubcentric to NON, but I like to have perfect centered wheels for higher speed use
Old 04-08-2013, 08:11 AM   #18
bakerr6
Drives: 2013 raven black fr-s
thanks guys, I may see if there's a way I can do a vibration rate test and a variance test on whether not they are useful or not in the future. It would be a long ways away though with how busy we are during tax season and the few months after.
bakerr6 is offline   Reply With Quote
Old 04-08-2013, 06:24 PM   #19
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
You should use hub-centric rings if you cannot properly tighten a wheel.
If you can properly tighten(and torque) a wheel then you do not need them. Lug nuts are conical for this very reason, people.
Hub-centric rings = band-aids for improper wheel installation.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 04-08-2013, 09:45 PM   #20
wparsons
wparsons's Avatar
There's no way a centering ring does anything beyond hold the wheel in place while you're tightening the lugs. They're way too weak to actually hold a wheel in place with weight on it.
On this vehicle/wheels, what kind of seat are the lugs? If you're running either bowl or taper seat lugs and manage to get a wheel on off center something was done wrong in the installation.
VW guys swear by them because they use thread in bolts instead of pressed in studs with lugs and it's a HUGE pain in the ass to get a wheel lined up if it isn't hubcentric, but if you can set the wheel on the studs it isn't so bad.
flickr
Old 04-08-2013, 10:02 PM   #21
Huehuecoyotl
Thats not my point, I rather have the wheel perfectly centered, and the lugs dont do that as well as the rings IMHO
Old 04-09-2013, 12:26 AM   #22
deucethemoose
The lugs do that perfectly well, actually.
If you want your wheels perfectly centered you need to tighten the lug nuts gradually in star pattern.
Old 04-09-2013, 01:40 AM   #23
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The Toybaru uses a conical seat, which is the best kind for alignment and torquing.
I've always disliked VW and other German cars (only the German cars it seems too...) that use bolts to mount the wheels to the hub. Just about every other car in the world uses studs on the wheel hub with nuts, making it easy and much quicker to change out with much less frustration and chance of messing up the threading in the wheel hub (because there is none!) Much easier to replace a damaged stud than fix/replace a damaged wheel hub because of messed up threading or seized bolt...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 04-09-2013, 01:36 PM   #24
wparsons
wparsons's Avatar
Unless you're using square seat lugs I would have to disagree.
I was asking the other guy what style he was using on his car, not the FRS/BRZ, but you're right!
The only thing better about the German style is that it's MUCH easier to run longer "studs" if you need to, everything else you mentioned is a very real concern.
flickr
Old 03-23-2014, 11:22 PM   #25
xGoggles88x
Drives: 22013 frs and 240sx
Where can I buy these rings?? I have some rotiforms blq and I would like to throw them on for safety.
xGoggles88x is offline   Reply With Quote
Old 03-24-2014, 10:58 AM   #26
gramicci101
Off Topic
They don't increase safety, they just help keep the wheel centered while you put the lug nuts on. Our wheels are lug centric, not hub centric. This means that the lug nuts perform the duty of locating and centering the wheel. Hub centric wheels have flat (not conical or acorn) lug nuts and rely on the hub to keep the wheel centered. Once you've got the lug nuts on, incrementally tighten them in a star pattern until you reach your torque value. That will center the wheel.
Old 03-24-2014, 03:42 PM   #27
mfbmike
Drives: 2013 FRS, 2008 R32
Hub centric rings are not necessary.
If they help you sleep better at night, then put them on.
"But they are only 10 bucks"
Chipotle > hub centric rings
mfbmike is offline   Reply With Quote
Old 03-24-2014, 03:46 PM   #28
was385
Drives: MT WRB BRZ Limited, 2007 911s
I can't agree with this enough. Mounting up wheels on a 911 is a total PITA with those lug bolts.
was385 is offline   Reply With Quote
Hubcentric Rings Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 06-08-2016 01:42 PM
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
works kiwami hub rings? derka-derka AUSTRALIA 3 01-12-2013 07:52 PM
