Old 04-05-2013, 02:11 PM   #15
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I've been searching around online to see if there's any more info posted on this particular failure aside from that thread but I haven't found anything.
As it stands, there was no indication given that the failure was caused by an impact. When you hit something, all bets are off. I've bent stock wheels pretty badly doing that and you know they're built to a high standard, even just for liability.
I didn't think you were attacking me. Sometimes I get a bit smartass online. It's the British heritage coming out.
Nathan
SubieNate is offline   Reply With Quote
Old 04-05-2013, 02:15 PM   #16
Cheddar
Saving them pennies...
Nothing on this earth is perfect. Everything has a failure rate. May it be 1% or 0.00000000000000001%. Nothing last forever.
Cheddar is offline   Reply With Quote
Old 04-05-2013, 03:25 PM   #17
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Candy corn does.
supramkivtt2jz is offline   Reply With Quote
Old 04-05-2013, 03:41 PM   #18
Originally Posted by mrk1 View Post
Really need to hear a first hand explanation of what happened for this to have any validity.
Anyone can google image search for days finding pictures of broken parts.
Quick example. A buddy of mine has a broken team dynamics wheel hanging on his wall. The wheel was off his rally car. Some dude saw it and then decided TD wheels were weak. My buddy pointed out that he should have seen the rest of the car, a high speed impact with the wheel caused an end over end tumble. Any wheel would have broken.
I was there first hand and witnessed the off. The owner was driving. What do you want to know?
Old 04-05-2013, 03:55 PM   #19
Did he ever inspect the mounting "ears" where it mounts to the hat? Not the easiest to do, I check mine as much as I can after removing pads, but removing the caliper is somewhat annoying just to check..
The car in question typically has a full crew regularly working on it...
Old 04-05-2013, 04:34 PM   #20
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The key thing to notice here is the way the rotor mounts onto the top hat versus the AP Racing kit.
Ummm... Pardon me but what am I noticing?
Old 04-05-2013, 04:55 PM   #21
ST185RC
Drives: White Out FR-S
Human stupidity, the only man-made product that will never fail; if only it can be harnessed as an energy source.
ST185RC is offline   Reply With Quote
Old 04-05-2013, 04:57 PM   #22
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Even cold november rain.
industrial is offline   Reply With Quote
Old 04-05-2013, 05:05 PM   #23
jamal
jamal's Avatar
Drives: Legacy GT
I have never liked the way the wilwood rotors go together. IMO the reason this happened is because there is zero float and no ability for the rotor/hat interface to compensate for thermal expansion or a slight misalignment.
Most other two piece rotors use a drive pin with float which allows the rotor to expand independently of the hat as well as reduce brake piston knockback. The wilwood hats are just straight bolted on there.
Here's a nice post by essex that explains the difference with more detail
http://www.essexpartsblog.com/news/f...ng-brake-discs
And Stoptech has some pictures of their mounting system here:
http://www.stoptech.com/products/rot...ch-aero-rotors
and more here: http://www.zeckhausen.com/StopTech/R...eplacement.htm
jamal is offline   Reply With Quote
Old 04-05-2013, 05:12 PM   #24
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
The lack of comments about the oxidation and surface rust evident in the cooling fins and elsewhere leads me to believe this is a non issue?
Even though it is minimal, is this not relevant in some way perhaps?
CircuitJerk is offline   Reply With Quote
Old 04-05-2013, 05:20 PM   #25
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
It didn't go unnoticed but I never mentioned it because again too many variables to judge that alone.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 04-05-2013, 05:36 PM   #26
SubieNate
SubieNate's Avatar
Most likely just an artifact of getting really hot repeatedly. Most anticorrosion coatings etc don't last at track temps. I'm not sure this is the case but it's a guess. Height temps encourage oxidation as well.
Old 04-05-2013, 07:41 PM   #27
Excellent response answered the question for me!
Old 04-05-2013, 07:57 PM   #28
Hanakuso
This was on a rather well known time attack car... those are JRZs you see in the back. The pic is less than a month old; I was there when it happened.
But isn't this specific Wilwood mounting basically the same as the "Sprint" kit?
Hanakuso is offline   Reply With Quote
Trunk release failure - BRZ Smilez CANADA 35 07-15-2019 10:15 PM
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
A pessimist's take on sales success / failure Mess11 Scion FR-S / Toyota 86 GT86 General Forum 137 11-24-2011 01:10 PM
