#15 | |
The Stig's German cousin
What you say is absolutely true for a competition where you have maybe one warm up lap - the skinnier tire will be in its happy place and the wider tire...not so much. What I would then suggest is a wide tire with a softer tire compound (i.e. with a lower operating temperature range). Depending on tire rules for your series, this may be difficult or even impossible to accomplish. |
#16 |
Drives: Black frs project
more surface area = lower presure/area = lower friction at = coefficient of friction.
and the coefficient of friction term is also dimentionless when solved for...Ever wonder how a good bicycle racer going downhill in the tight twisty mountain roads on LESS THAN TWO SQUARE INCHES of contact patch can pull away from the motorcycles and other suport vehicles? Paul Handley "the racing and high performance tire" explains this fact in great detail...area controls heat it is the only method to do this. Heat builds up over time... |
#17 |
Track Junkie
Drives: Faster than the Stig!
Im running 245 RS3's on a set of wheels and 225 BF goodrich R comps on another set. I would not go wider than 235 for a bolton on car.
#18 | |
#19 | |
Drives: Some rust bucket
#20 |
#21 |
Im Trying 205 Stickies this weekend...
#22 |
#23 |
Both days instructing.
#24 |
both days!
#25 |
gahhhhhh okay.
#26 |
If the friction coefficient was constant, a 165 wide tire would have the same grip as a 345 wide tire. But the friction coefficient is obviously dependent on the surface pressure (weight of the car divided by the contact patch) and the temperature reached with that surface pressure. (And anything below or above the optimal temperature reduces the friction coefficient.)
At the Autocrosses I participate almost all people in my class run on narrower tires than I (235) (mostly Honda Integra DC2 and Renault Clio RS/Sport). All races this year have been pretty cold and even wet and they were all won by people on DC2's on just 205 and 195 wide tires. People here run on Toyo R888 or Yokohama A048 (street tire class). I think that these type of tires need possibly more surface pressure in order to obtain enough heat (than the ones people typically use in the US or maybe people racing in the US are simply exposed to much warmer weather). Also, I talked to a guy with a Celica GT-Four who won in his class and he ran on 225 wide tires with a tire pressure of only 27 psi (cold). |
#27 |
Conedancer
Drives: 2013 Subaru BRZ SWP
As a autocrosser...and As per the rules for my class, I am allowed a 9 in wheel as well as a tire width up to a 265. I have both 245 and 255 on two different sets of wheels. There are a number official reasons that we choose those sizes...weight, grip, performance and gearing...since most of our stuff is in 2nd gear. So we look for a tire size that will help with that. Additionally, we want fhe widest tire so it has the most lateral grip, so in the case of autocross, the heavy transitions on a wider tire help with heat management...as a thinner tire will heat up more, loosing valuable grip..this is the autocrosser perspective. I don't find that I lose feeling at all, matter of fact its enhanced. This is for a nationally campaigned car in STX.
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#28 |
That's a good point. Maybe because Autocrosses (in the US) are usually mostly driven in 2nd gear (more torque) and since there are more turns/time, tires are getting hotter and wider tires are an advantage.
| Will this fit? (width, offset and tire size Qs) | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4468 | 04-15-2024 12:31 AM |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Track width | -max- | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-21-2012 06:37 PM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
