Old 02-04-2013, 05:13 PM   #15
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Originally Posted by zaptorque View Post
Both my dash and key trunk release button make you hold for at least 2 seconds.
Same here.
The key trunk release button delay I can live with, but the dash button delay is just frustrating.
Razzle is offline   Reply With Quote
Old 02-04-2013, 05:23 PM   #16
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
yup... delay here too. I rarely use the button in the car, maybe twice, but each time I had to hold it down.
sbxjap is offline   Reply With Quote
Old 02-04-2013, 05:41 PM   #17
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Never quite understood why the Aussies and Brits call it a boot. A bonnet I can understand.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 02-04-2013, 06:10 PM   #18
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I don't mind it on the dash/key but I wish the button underneath the trunk opened it instantly
dori. is offline   Reply With Quote
Old 02-04-2013, 06:15 PM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Can we Lock our trunks? I would like to be able to put something in the trunk and have it be secure even if someone breaks into my car. Every other car I've owned with a trunk had this ability.
PRO86 | STL | LuckyDog
Old 02-04-2013, 06:18 PM   #20
Shagaliscious
Drives: Firestorm FR-S (MT)
Yup. If you open your trunk and look to the left. There is a little button that makes it so you have to use the key to open it.
Edit, just realized this may not be what you are talking about, since you can still fold the seats down (I think).
Old 02-04-2013, 06:31 PM   #21
rice_classic
I will go check this out.
Old 02-04-2013, 06:37 PM   #22
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
What button under the trunk? What?
Carbon420 is offline   Reply With Quote
Old 02-04-2013, 06:49 PM   #23
sierra
Drives: Skoda Yeti DSG diesel 4x4
Well there you go! I didn't even know the boot would open itself.
I assumed the button on the dash just unlocked it so I could open it with the switch back there. Same with the button on the keyless thingy because the 2 sec delay meant it never operated it. Barely 1 sec on the dash button.
Now I understand[?] that being in the proximity unlocks it, same as the doors and those 2 buttons operate and release the lock.
Thanks guys!
sierra is offline   Reply With Quote
Old 02-04-2013, 07:05 PM   #24
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Originally Posted by mkiisupra View Post
There are two 'boot access buttons' being discussed here. The OP has a concern about the dash button being too sensitive, while others are talking about the key fob button seems to take a second or two to release... Back to your post, nothing to see here.
Eric G
My dash button also takes a few seconds....
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 02-04-2013, 07:18 PM   #25
bergyb
bergyb's Avatar
Drives: 2013 Argento FRS AT
My truck button takes a good couple seconds of pressure to finally open.
bergyb is offline   Reply With Quote
Old 02-05-2013, 02:58 PM   #26
Dake
Dake's Avatar
Unlike many cars that allow you to release and fold down the seatback from inside the cabin, the only way to do this in ours is via two straps inside the trunk - one on each side. So if you hit the little button inside the trunk to disengage the electric release (key fob and dash button) the only way into the trunk is with the key or a crowbar.
You can tell the seatback is secured because if you pull on the straps and then go inside the cabin and look, you'll see two red buttons have popped up at either corner indicating the latch is disengaged. Just pull the seatback forward and slam it back and they'll re-latch (the red will disappear).
Oh and yeah, both my fob and the dash button require you hold for a couple of seconds. It's a little annoying, but I understand why and it would be more annoying to accidentally pop the trunk when you don't want to.
Dake is offline   Reply With Quote
Old 02-05-2013, 03:30 PM   #27
Carbon420
I don't have a button or a switch or anything on my trunk. Is this cause of my carbon fiber?
Old 02-05-2013, 04:39 PM   #28
Shagaliscious
Wait, so you can only fold the seats down through the trunk? This is good.
