Old 02-04-2013, 09:30 AM   #1
MarkMash
MarkMash's Avatar
Drives: Toyota 86
Anyone had this?
I was changing the brightness of the dash lights and my finger just brushed against the boot open button as I'm driving up to a red light...
had to pull over and close the boot again.
(trunk for you US folk)
That's the ONLY thing I don't like that much about it - hardly a thing, just found the button so sensitive in a spot that is hard to see and right next to something else you might want to adjust....
MarkMash is offline   Reply With Quote
Old 02-04-2013, 09:36 AM   #2
MyRx
MyRx's Avatar
Ironically, my boot [trunk] release takes a couple second delay to actually work. But let see others' boot button is that sensitive.
And thanks, learned a new word
Old 02-04-2013, 09:40 AM   #3
whaap
whaap's Avatar
I haven't noticed that. However it is not something I would be concerned about because once I have adjusted my instrument lights, which I have already done, I never change that setting. I won't be going back to that area of the dash again unless I'm reaching for the boot button.
whaap is offline   Reply With Quote
Old 02-04-2013, 09:59 AM   #4
raleav
trunk release delay
Actually, it's something that can be programmed by the dealer. I hate having to wait 2 seconds to open it on my key, so in the manual it says you can have the dealer set it so it opens on first touch. I guess it's a safety issue so it's not always opening by accident while in your pocket. Same goes for the dash button. It's programmed the same as the key. I'm also going to have them set the loudness of the beep to maximum when you hit the lock button on the key. Sometimes, I can barely hear it!
raleav is offline   Reply With Quote
The Following User Says Thank You to raleav For This Useful Post:
kthxbai (02-04-2013)
Old 02-04-2013, 11:10 AM   #5
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
My boot also only opens after I keep the button down for at least 2 seconds.
It's kinda annoying. I want it to open immediately. I use the boot eveyday, at least twice a day.
So it's programmable by the dealer you say.
Thanx
Razzle is offline   Reply With Quote
The Following User Says Thank You to Razzle For This Useful Post:
lantsalot (02-04-2013)
Old 02-04-2013, 12:17 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I've had bags get stuck on the emergency pull open for the trunk and open the trunk on me...
Kinda scary.
Old 02-04-2013, 12:33 PM   #7
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Mine also takes a few seconds
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 02-04-2013, 12:47 PM   #8
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
There are two 'boot access buttons' being discussed here. The OP has a concern about the dash button being too sensitive, while others are talking about the key fob button seems to take a second or two to release... Back to your post, nothing to see here.
Eric G
mkiisupra is offline   Reply With Quote
Old 02-04-2013, 12:58 PM   #9
Deebeaux
Deebeaux's Avatar
Drives: i walk the streets.
I wonder if there's different programming for the dash boot/trunk release button, the OP is in Australia, but the US folk (and one from South Africa) that has posted so far have the 2 second delay. I actually thought something was wrong with my trunk button when I first picked up the car (didn't have a chance to peruse the owner's manual yet) and then realized I have to push and hold it for 2 seconds. It's about 2-3 seconds on my key fob as well. Might be worth a call to the dealer about some re-programming to see if it effects just the fob or the dash button as well.
--- Deebeaux
--- Former '13 FR-S Turbo Owner
Deebeaux is offline   Reply With Quote
Old 02-04-2013, 01:01 PM   #10
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
My dash button has a 2 second delay or so, as does my key fob. Both are kinda annoying, but i've learned to live with it.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 02-04-2013, 03:21 PM   #11
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
It's a trunk in Canada too BTW. But no I haven't. I actually have to hold mine for three seconds (both on key and in car) to open my trunk.
Carbon420 is offline   Reply With Quote
Old 02-04-2013, 03:27 PM   #12
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
Eric G
Both my dash and key trunk release button make you hold for at least 2 seconds.
zaptorque is offline   Reply With Quote
The Following User Says Thank You to zaptorque For This Useful Post:
mkiisupra (02-04-2013)
Old 02-04-2013, 03:35 PM   #13
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Kinda scary.
I've had this happen with stuff in the trunk too. Had to pull over and close the trunk.
Things that aren't strapped down have a tendency to fly around in this car. I've given up on using those weighted mounts for GPS that sit on the dash. You take one curve and the GPS is in the backseat.
MVJ1975 is offline   Reply With Quote
Old 02-04-2013, 04:14 PM   #14
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Can also confirm that my dash and fob buttons both have a 2 second delay. Don't mind it too much since it prevents OP's situation from happening.
Plus I'm getting older and much much more patient these days - what's an extra 2 seconds going to do to your life?
enouf is offline   Reply With Quote
