| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: '13 BRZ Ltd WRB
They're interchangeable. Not much on these cars isn't.
#16 |
Correct. When installing a "crash bolt" the manual calls for placing a 14mm bolt in the 16mm top hole. This gives some wiggle room to adjust. The purpose is to correct alignment when it's out of spec from a crash, but obviously it has other uses. For eccentric (lobed) bolts, you can replace top or bottom depending on which size you get. Some are made for 16mm, some for 14mm.
| The Following User Says Thank You to 2point0 For This Useful Post: | Dwood11 (12-13-2013) |
#17 |
When you order these from Scion it has an SU part number.
Its a subaru part, with a scion part number taped to it They are identical bolts both from Subaru.
#18 |
If camber is maximized using the replacement bolt as shown in the video, does toe need to be re-zeroed?
And if yes can this for instance be accomplished with a simple wheel alignment gauge such as this? http://www.gunson.co.uk/item.aspx?item=1812 |
#19 | |
I can't really tell what all that product does, but the simplest toe adjustment tool is usually a plate up against each wheel with slots in the edges for you to instert a tape measure on each end (front/back) and measure for any difference between the two. Some guys just use string. Here's a set of toe plates: http://www.longacreracing.com/catalo...id=152&catid=5
#20 |
2point0, Thank you for your tip.
What toe setting is typically applied in autocrossing? |
#21 | |
Drives: Exige S 240
[EDIT: so no, as expected, it is a "fat" bolt on top from stock. Best value for money mod so far, may I add.] Last edited by Guillaume; 02-18-2014 at 12:54 PM. |
#22 |
Drives: GBS Limited 6MT
Did this a couple days ago. In case anyone is curious, you will need a 19mm socket/wrench.
| The Following User Says Thank You to u/Josh For This Useful Post: | hmong337 (01-04-2014) |
#23 |
Glorious BRZ Master Race
Drives: Subaru Libird
My BRZ came with 16mm top bolts and did not have 14mm bolts up top from the factory. I had to buy the 14mm camber bolts (which are same as bottom bolts).
| The Following User Says Thank You to switchlanez For This Useful Post: | Guillaume (01-04-2014) |
#24 |
Drives: Exige S 240
After looking up some more information I came to the conclusion that the service manual does indeed suggest to replace the stock 16mm upper bolts by 14mm ones to get more camber. I think I understood now.
![]() ![]() On a related subject, despite your problem with slotted holes (http://www.ft86club.com/forums/showp...7&postcount=24), you do confirm that this mod is 100% OK on stock dampers, right? Last edited by Guillaume; 01-04-2014 at 04:33 AM. |
#25 |
Drives: GT86 raven
hey, this might be a stupid question, but I got the bolts ready and want to do this thing next week. My question is, do you reuse the nut from the original bolt? Since the old one is a 16 and the new one is a 14 this seems kinda weird to me but in the video it looked like they did reuse the old nut, if not what is the part number for it? :>
| Crash bolts alignment change | ABQautoxer | Tracking / Autocross / HPDE / Drifting | 39 | 03-24-2014 05:45 PM |
| Where to buy Whiteline Camber Bolts | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 07-26-2013 02:05 PM |
| Another crash bolts alignment thread | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 10-28-2012 12:29 AM |
| replace front crash bolts to add camber? | Matt Andrews | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 06-15-2012 10:05 AM |
