Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-31-2012, 12:24 AM   #15
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
im curious as to why so many people are going with cusco rear lower arms? is this to dial out negative camber when you lower the car? is this a big issue with these things? seems an expensive method, surely there are aftermarket camber bolts available?
car looks good mate, i have my wheels sitting in their boxes. havent even opened for a peak haha.
spiller is offline   Reply With Quote
Old 10-31-2012, 12:40 AM   #16
Nardi330
Nardi330's Avatar
Drives: 86
because it's easiler to DIY fit than replacing bushes (eg. Whiteline rear upper camber bushes) plus the range of camber adjustment is more than just bushes.
Nardi330 is offline   Reply With Quote
Old 10-31-2012, 02:35 AM   #17
Xauterus
Drives: GTS 86 Galaxy Blue
When you fit just the offest bushes you are stuck with the camber they give you. Also the adjustable arms mean that you can get it same both sides.
Xauterus is offline   Reply With Quote
Old 11-01-2012, 12:33 AM   #18
spiller
are they bushes in the cusco arms polyurethane/spherical or rose jointed?
Old 11-01-2012, 03:59 AM   #19
Xauterus
They are spherical but sealed with a proper boot to keep the dirt out.
Old 11-01-2012, 11:12 AM   #20
TUFSIG
TUFSIG's Avatar
Drives: Mitsubishi 3000GT
Rims look good mate, nice choice, looking forward to pics when its lower
TUFSIG is offline   Reply With Quote
Old 11-06-2012, 10:17 AM   #21
Xauterus
Here is some updated pics with the car lowered 25mm at the front and 30mm at the rear. The camber on the front is a touch too much.
Booked in for a wheel alignment at 8 am tomorrow.
The Following User Says Thank You to Xauterus For This Useful Post:
MarkMash (11-06-2012)
Old 11-06-2012, 05:13 PM   #22
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
So tell me, what's it like with huge semi slicks? A bit le boring?
Surok is offline   Reply With Quote
Old 11-06-2012, 10:20 PM   #23
Xauterus
No its much better now.
I guess you lose that low speed lack of grip, but I am not looking for a really loose car. It changes the car a fair bit but certainly does not make it worse.
I had it wheel aligned today, from the 30mm drop on the rear it had 25mm toe out. No wonder it felt like it wanted to weave all over the road. The toe adjustment is maxed out so I will raise it up at least 5mm to see if that reduces the toe out slightly. It still had 2.5 mm toe out after the alignment.
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 06:55 AM
Galaxy Blue - NZ diss7 AUSTRALIA 5 09-25-2012 07:51 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 10:55 PM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 11:09 PM
