Old 03-11-2014, 01:48 PM   #15
ButtonMasher
ButtonMasher's Avatar
Drives: 2013 Ultramarine Scion FR-S
Originally Posted by Simon99 View Post
I had what though was a whistling noise which ended being caused by the radio on an unplugged aux cable when affected by automatic volume control (the shit that turns up the volume when you WOT and turns it down when you stop) ?
Sent from my SGH-I337M using Tapatalk
I ought to give that a try. I recently turned on the auto volume control. But I have no aux cable :/
Sent from my Nexus 4 using Tapatalk
ButtonMasher is offline   Reply With Quote
Old 03-11-2014, 03:07 PM   #16
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
But it was clearly coming from the inside, more like a whiiiizzzzz sounds, not a fuuuuuuushhhhhh from a mini wind whistle
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 03-11-2014, 08:55 PM   #17
ButtonMasher
Oh shoot you're right. Well I have no idea what it is then. I think it might be the sound tube?
Old 03-11-2014, 09:15 PM   #18
Simon99
Simon99's Avatar
Could, does it sounds like an induction noise ?
Old 03-11-2014, 09:19 PM   #19
ButtonMasher
Yes. Exactly like a turbo or supercharger would make. Only quieter
Old 03-11-2014, 09:29 PM   #20
Simon99
Simon99's Avatar
Could really be the induction noise ported in the cabin. Block the hole using the 12v plug in the glovebox. I believe the induction tube open in the pedals area although I'm not 100% positive !
Old 03-12-2014, 03:12 AM   #21
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Its the differential likely you're hearing. It really becomes amplified when you install a Perrin T tranny mount or other tranny support mods. Even with stock carrier I could hear it. Its faint and like a whine...and most noticeable around 67-74mph
Old 03-12-2014, 11:47 AM   #22
Simon99
Simon99's Avatar
Perhaps changing fluids could smoothen that noise ?
Old 03-12-2014, 01:59 PM   #23
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
serious question: does your car have a clear bra on the mirrors?
supramkivtt2jz is offline   Reply With Quote
Old 03-12-2014, 06:25 PM   #24
OICU812
Just a dude
OICU812's Avatar
Somewhat yes I changed to redline MTL and it did help. I also went from a Perrin T mount to a Whiteline Mount and it helped immensely almost back to stock nvh level. That's why my guess is strong with that, however if OP is on stock tranny mount then yes fluids help "abit" but this car inherently does transmit some nvh from diff I've hear it on several of other club members cars to. Past that you can use mlv on tranny tunnel and trunk area, that was huge decrease in cabin noise overall for me.
Old 03-17-2014, 02:37 PM   #25
ButtonMasher
I really don't think it's my diff. On my way to the gas station, the whistling noise was horrible. But as soon as I started up the car again, it was gone. Should I be worried?
Also it seems to be coming from the right side of the car
Old 03-17-2014, 06:54 PM   #26
AznBRZer
Drives: 16 CBS WRX Limited
Originally Posted by blue_frs View Post
Is it actually a whistling or a humming/whining noise it could be the resonant frequency which is around 70mph
Sent from my DROID4 using Tapatalk 2
Could you explain this?
I noticed on Saturday that there's some weird wind noise as I hit 70. I've had some bad buffeting for a while thanks to an attempted break in, but now it sounds like there's a break in the seal between the window and the gasket. It's a constant low-pitched hollow sounding wind noise.
AznBRZer is offline   Reply With Quote
Old 04-28-2014, 10:33 AM   #27
ButtonMasher
So the whistling sound returned this morning. It gets louder and quieter as the RPMs rise and drop. Dealer says they won't fix it until it becomes a daily, recurring problem. It's quite annoying
Old 04-28-2014, 08:31 PM   #28
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Weird. I have the "whistling" sound at ~70mph on the freeway and was told it was the differential. Never heard it at low speeds before.
l0aded is offline   Reply With Quote
Best sound BAE Engine, Exhaust, Transmission 4 09-30-2012 09:30 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
BRZ exhaust sound! ilikecars86 BRZ First-Gen (2012+) — General Topics 16 04-13-2012 03:26 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
