Old 08-18-2023, 03:37 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Aluminum and brass springs are very limited use. Brass isn't uncommon as a spring but it has to be heavily alloy'd.
The aluminum springs threw me. Color me schooled.
Old 08-18-2023, 04:03 PM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've read where it is a good idea to remote mount the sensor to an area with less vibration than the engine.
Old 08-18-2023, 04:12 PM   #17
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Ok ok... Can't make a typical spring out of aluminum or brass.
No, no. You're still getting things wrong. Aluminum springs are atypical.
Old 08-18-2023, 04:15 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They hurt my brain.
We looked into using a brass spring in our charging contact assembly but ultimately realized it wasn't really affecting anything so we went with stainless. I haven't seen many coil springs made that way even though I know they exist, I believe the tension spring on motor brushes are copper a lot of the time, if they have brushes that is. Don't know what you would use an aluminum spring for.
Old 08-18-2023, 04:25 PM   #19
Ultramaroon
not playing cards
lol I C wat U did there
Old 08-18-2023, 08:45 PM   #20
Ultramaroon
not playing cards
If I hadn't already done it a dumber way, I would've done that. Those things ARE tuning forks.
I'm already partway there because my gauge is mechanical. I hoped to see more detailed pressure fluctuation but I think the tube is too long and skinny.
Old 08-19-2023, 01:44 AM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Brass is probably better for corrosion resistance. Probably aluminum too. Aluminum is probably better for weight or where magnetic fields are an issue.
Old 08-19-2023, 05:34 AM   #22
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
They are Alloys of their base metal. Like steel is I suppose.
gen3v8 is offline   Reply With Quote
Old 08-19-2023, 08:54 AM   #23
blsfrs
blsfrs's Avatar
I had always used mechanical gauges until someone pointed out that if it were to fail you would be pumping hot high pressure oil into you cabin.
Old 08-19-2023, 02:47 PM   #24
Ultramaroon
not playing cards
Yeah. I went into it deliberately. Now, after the lame results, I'm somewhere between too lazy, cheap, and indecisive about the switch to an electrical one.
Old 08-25-2023, 11:48 AM   #25
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Slight update... So I just heard back from prosport themselves and they say to use 18ft of tq when installed in the top of the block.
autoracer86 is offline   Reply With Quote
Old 08-25-2023, 11:54 AM   #26
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
For the NPT threaded sensor or the adapter that goes into the block?
dragoontwo is offline   Reply With Quote
Old 08-25-2023, 12:20 PM   #27
autoracer86
Drives: Toyota GT86
Adapter into the block.
Old 08-25-2023, 12:24 PM   #28
dragoontwo
dragoontwo's Avatar
Looking back on the first page it appears through no fault of either party, you and nohavemsg are talking about different fitting torques.
Kobe Steel Joystick Off-Topic Lounge [WARNING: NO POLITICS] 26 11-06-2017 06:04 AM
Stainless steel header vs mild steel header interest mav1178 Engine, Exhaust, Transmission 18 03-06-2017 08:23 PM
FS: gold brass knuckle shift knob 86design Interior Parts (Incl. Lighting) 11 01-28-2013 05:30 AM
Steel wheel Silp3 New England 9 01-24-2013 10:14 AM
