Old 08-18-2023, 04:37 PM   #15
Aluminum and brass springs are very limited use. Brass isn't uncommon as a spring but it has to be heavily alloy'd.
The aluminum springs threw me. Color me schooled.
NoHaveMSG (08-18-2023)
Old 08-18-2023, 05:03 PM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've read where it is a good idea to remote mount the sensor to an area with less vibration than the engine.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 08-18-2023, 05:12 PM   #17
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Ok ok... Can't make a typical spring out of aluminum or brass.
No, no. You're still getting things wrong. Aluminum springs are atypical.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
NoHaveMSG (08-18-2023), Ultramaroon (08-18-2023)
Old 08-18-2023, 05:15 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They hurt my brain.
We looked into using a brass spring in our charging contact assembly but ultimately realized it wasn't really affecting anything so we went with stainless. I haven't seen many coil springs made that way even though I know they exist, I believe the tension spring on motor brushes are copper a lot of the time, if they have brushes that is. Don't know what you would use an aluminum spring for.
Old 08-18-2023, 05:25 PM   #19
lol I C wat U did there
EAGLE5 (08-19-2023)
Old 08-18-2023, 09:45 PM   #20
If I hadn't already done it a dumber way, I would've done that. Those things ARE tuning forks.
I'm already partway there because my gauge is mechanical. I hoped to see more detailed pressure fluctuation but I think the tube is too long and skinny.
blsfrs (08-19-2023)
Old 08-19-2023, 02:44 AM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Brass is probably better for corrosion resistance. Probably aluminum too. Aluminum is probably better for weight or where magnetic fields are an issue.
The Following User Says Thank You to EAGLE5 For This Useful Post:
NoHaveMSG (08-19-2023)
Old 08-19-2023, 06:34 AM   #22
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
They are Alloys of their base metal. Like steel is I suppose.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
NoHaveMSG (08-19-2023), Ultramaroon (08-25-2023)
Old 08-19-2023, 09:54 AM   #23
blsfrs
blsfrs's Avatar
I had always used mechanical gauges until someone pointed out that if it were to fail you would be pumping hot high pressure oil into you cabin.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
bcj (08-19-2023), Ultramaroon (08-19-2023)
Old 08-19-2023, 03:47 PM   #24
Yeah. I went into it deliberately. Now, after the lame results, I'm somewhere between too lazy, cheap, and indecisive about the switch to an electrical one.
blsfrs (08-19-2023)
Old 08-25-2023, 12:48 PM   #25
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Slight update... So I just heard back from prosport themselves and they say to use 18ft of tq when installed in the top of the block.
autoracer86 is offline   Reply With Quote
Old 08-25-2023, 12:54 PM   #26
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
For the NPT threaded sensor or the adapter that goes into the block?
The Following User Says Thank You to dragoontwo For This Useful Post:
NoHaveMSG (08-25-2023)
Old 08-25-2023, 01:20 PM   #27
autoracer86
Drives: Toyota GT86
Adapter into the block.
Old 08-25-2023, 01:24 PM   #28
dragoontwo
dragoontwo's Avatar
Looking back on the first page it appears through no fault of either party, you and nohavemsg are talking about different fitting torques.
Kobe Steel Joystick Off-Topic Lounge [WARNING: NO POLITICS] 26 11-06-2017 07:04 AM
Stainless steel header vs mild steel header interest mav1178 Engine, Exhaust, Transmission 18 03-06-2017 09:23 PM
FS: gold brass knuckle shift knob 86design Interior Parts (Incl. Lighting) 11 01-28-2013 06:30 AM
Steel wheel Silp3 New England 9 01-24-2013 11:14 AM
