Old 05-29-2023, 06:14 PM   #15
ruturaj001
Drives: BRZ 2023
Originally Posted by RToyo86 View Post
3mm technically clears but doesn't leave much stud left for nut to grab onto. Not sure I'd feel comfortable running that on track but that's me.
Some 2.5" Arps would solve that.
Originally Posted by autoracer86 View Post
Will you need extended studs as well ?
If I had to install spacers then I am ordering RPF1 17x8" with 35mm offset with 225 tires the next day. That would add about 6-7mm to clearance. I am planning to get wheels anyways, I was just waiting for these tires to wear out.
ruturaj001 is offline   Reply With Quote
Old 05-30-2023, 08:45 PM   #16
ruturaj001
Drives: BRZ 2023
Took some pictures
The Following User Says Thank You to ruturaj001 For This Useful Post:
autoracer86 (06-02-2023)
Old 05-31-2023, 10:37 AM   #17
Ohio Enthusiast
Drives: 2018 BRZ
Looks more than I have on my track setup. Send it!
Ohio Enthusiast is offline   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
ruturaj001 (05-31-2023), strat61caster (05-31-2023)
Old 06-01-2023, 09:52 PM   #18
ruturaj001
Drives: BRZ 2023
Just an update, I didn't end up using spacers. I used drill bits from smoother end to figure out how much space there is, it's between 6mm and 7mm. I am thinking about hypergram wheels now when time comes, they add about 8mm and 225 tires would take 5mm out of it, leaving me at ideal 10mm clearance.
Camber bolts and stock suspension rub Cubix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-02-2021 01:46 AM
20mm & 25mm v3 bolt on spacers. Whiteline camber bolts Newlovekid Wheels and Tires 4 09-01-2014 02:35 PM
Koni/GC Suspension, SPC LCA's, Wilwood BBK, OEM Camber Bolts SportInjected Brakes, Suspension, Chassis 13 08-22-2014 09:52 AM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 05:45 PM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 10:44 AM
