Old 06-08-2023, 12:27 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Tokay444 View Post
There is no such thing as second gear lockout.
Typical Tokay post. No useful information, just being contentious when you know what the guy means and he just used an incorrect term.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Clipdat (06-08-2023), spike021 (06-09-2023), Ultramaroon (06-08-2023), villainous_frx (06-09-2023)
Old 06-08-2023, 12:41 PM   #16
Tokay444
Follow me for more tips on using the correct terminology.
Old 06-08-2023, 12:50 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Except you never offer the correction
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 06-08-2023, 02:01 PM   #18
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
OP should have said "blocked" out.
Putting a "B" in front of "locked" makes it correct terminology.
See how easy that was?
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (06-08-2023), Tokay444 (06-08-2023)
Old 06-08-2023, 03:36 PM   #19
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by redvee86 View Post
I know there is a first gear lock out...
There is no first gear lockout either. You just need more REVs when downshifting
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
The Following 3 Users Say Thank You to RACECAR go brrr! For This Useful Post:
blsfrs (06-08-2023), NoHaveMSG (06-08-2023), soundman98 (06-10-2023)
Old 06-08-2023, 06:20 PM   #20
Ultramaroon
not playing cards
Ultramaroon's Avatar
Incorrect. Look at the parts breakdown in the service manual. There is a first-gear limit mechanism.
Yes, the key is to double-clutch down into first. Be mindful of vehicle speed when doing so.
Old 06-08-2023, 06:36 PM   #21
RACECAR go brrr!
Uhh, is mine broken then? Because I've always been able to downshift into 1st gear at any speed without any issues... no double-clutching necessary.
Old 06-08-2023, 06:43 PM   #22
Ultramaroon
not playing cards
I've wondered about that since I drove someone else's which behaved like yours. Maybe the limit ball was left out when originally assembled.
Old 06-08-2023, 06:51 PM   #23
RACECAR go brrr!
Hmmmm. At what speed are you limited in downshifting to 1st?
Old 06-08-2023, 06:55 PM   #24
Ultramaroon
not playing cards
It requires a double-clutch blip at anything above 10-ish MPH. I know what you mean. I was shocked when I first encountered one that didn't resist.
Old 06-08-2023, 07:19 PM   #25
RACECAR go brrr!
Hmm. Well here's a video I made many years ago after getting into an argument with someone on Facebook about it, lol. I downshift into 1st at 15 and 20 both without double clutching. I'll also note I had to have a new transmission installed at 40k (because my 5th gear synchro went wonky) and that transmission also doesn't require double clutching. So I'm 2 for 2 on the "defective" 1st gear lockout if that's the case.
The Following User Says Thank You to RACECAR go brrr! For This Useful Post:
Old 06-08-2023, 09:32 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Considering how many times people find ball detents stuck to the drain plug, not surprising It's usually the one on the 3/4 shift fork that is most common due to that fork being able to over travel too far.
Old 06-08-2023, 10:01 PM   #27
Ultramaroon
not playing cards
Someday I'll crack open my original transmission to shim the input shaft bearing like we discussed. Will be interesting. Both of my transmissions are super picky about downshifting into first.
3/4 rod overtravel? Sounds like I need some schoolin'
NoHaveMSG (06-09-2023), soundman98 (06-10-2023)
Old 06-08-2023, 10:04 PM   #28
Ultramaroon
not playing cards
Hmm.
Oh, I believe you for sure. I've driven both flavors.
Do I need to be extra careful when shifting 1-2 in cold? lapsio BRZ First-Gen (2012+) — General Topics 49 11-22-2021 11:27 AM
2018 cold shifting konahic BRZ First-Gen (2012+) — General Topics 29 02-28-2020 06:09 PM
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 04:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 05:24 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
