Old 02-02-2020, 11:03 PM   #1
konahic
Drives: 2018 BRZ
2018 cold shifting
Howdy y'all, I have a 2018 BRZ Ts with about 4K miles on it. I got it used with 3K on it. When its cold it really doesn't want to go into 2nd gear. It takes about 15 minutes & 5 miles of driving before it gets easier. I live in Hawaii where its 68 degrees at 6am in January. So, freezing temps aren't an issue. I'm curious if anyone else has experienced this.
Back in the mid 80's when I was a Mercedes technician, we would put Redline MTL Fluid in 300E's to make them shift when it was cold. Anyone try that?
Any help/thoughts are greatly appreciated, Kato
konahic is offline   Reply With Quote
Old 02-02-2020, 11:31 PM   #2
StraightOuttaCanadaEh
Wes
Yes.
Keep changing trans fluid til the problem goes away. For me 2-3 flushes did it. Tried Redline and Motul. For me personally Redline was better. Motul is best once the car is warmed up but not the best while it’s warming up.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
why? (02-04-2020)
Old 02-03-2020, 01:05 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well I woundn't won't that particular oil weight, but I would put the recommended oil weight from Redline.
It helps, but it's still a few 5-10 minutes from a cold start that the shift feel nocthy at lest 1&2nd are.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
ElijahF (02-05-2020), why? (02-04-2020)
Old 02-03-2020, 04:23 AM   #4
JIM THEO
Drives: BRZ 2018
I live in Greece where ambient temps this period are about 10C and have experienced the same exactly problem, I changed once to Motul Gear 300 with no big difference and recently to Redline MT85 that improved 70-80% the gear changes at least with these temperatures.
Plus I ordered the Mtec neutral springs that helped a lot in my problem
JIM THEO is offline   Reply With Quote
Old 02-03-2020, 12:05 PM   #5
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Based on your climate and very low mileage I'd wait a bit to see if it works itself out. This is a common "issue" with the platform but I wouldn't rush to start flushing fluids just yet... let it break in for a while.
One trick I use regularly (even after changing fluids at 30k kms) is to just row through all the gears 1-6 once or twice before I leave in the morning while waiting for revs to drop. This seems to loosen everything up and then I have no issues.
wolffbite is offline   Reply With Quote
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
ElijahF (02-05-2020), Spuds (02-04-2020), Tcoat (02-03-2020)
Old 02-03-2020, 12:30 PM   #6
This^
It get's better when you have some miles behind you.
Old 02-03-2020, 12:31 PM   #7
Stomachbuzz
Drives: 2013 FRS
Same issue on my 2013 with 50k miles.
Didn't really notice it too much over the summer, but definitely a big issue when it was ~20F.
It was almost like uncomfortable how hard I had to pull to get it into 2nd gear. Obviously, I was pushing clutch pedal in all the way, shifting slowly and gently, but it was still odd.
Even when 50-60F, there is noticeable resistance going into 2nd gear when it's cold.
I swapped the fluid out for Redline MT85. I noticed zero difference in performance at any temp.
Stomachbuzz is offline   Reply With Quote
Old 02-03-2020, 01:04 PM   #8
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 75w80. BMW oil, $25/qt, but worth it. 20 thousand miles and buttery. Even with a lightweight shift knob.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 02-03-2020, 02:02 PM   #9
qqzj
Drives: MDX, Camry
How do you shift? I have the same problem. So the first one or two gear changes, I just double clutch it. It is inconvenient, but not a big deal.
I changed to motul at around 32k. Not much difference. Even slightly worse, like when the car was new. I think the hard to shift issue gets better when the mtf is a bit worn/used.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 02-03-2020, 03:53 PM   #10
Wes
Try the MTEC shifter springs. I have that, the Whiteline shifter support and Perrin trans insert and I never have issues shifting like I used to when that whole area was stock.
Instagram: @gt86ws
Stomachbuzz (02-05-2020)
Old 02-03-2020, 04:57 PM   #11
Lantanafrs2
Drives: 2013 frs red
My car gets notchy too when it gets below 60 degrees but improves when it's up to temperature. Check your clutch fluid level
Old 02-04-2020, 09:15 PM   #12
konahic
Drives: 2018 BRZ
Many thanks to all for your responses. I usually double clutch when first starting out, but that doesn't always help. I like the idea of rowing through all of the gears while waiting for the revs to come down. I'll try that. If that doesn't do it, I'll try switching the springs. I'm going to have to wait to change to Redline as there's none to be had around here. At least I know I'm not the only one experiencing this.
Kato
Old 02-04-2020, 09:15 PM   #13
konahic
Drives: 2018 BRZ
Kato
Old 02-04-2020, 11:31 PM   #14
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I recommend just giving it a few thousand more miles to break in before swapping fluids around.
Otherwise, good luck.
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 04:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 05:24 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
