Old 03-29-2023, 06:09 PM   #15
Kulebrero
Drives: GR86
Originally Posted by Ohio Enthusiast View Post
Another thing that was not brought here yet - are you running with stability control fully off? Long press on the left button. Otherwise you'd get traction and stability actuation of the brakes that will quickly overheat them.
Good question. I’m pressing the Track button until the dashboard changes to track format. Am I supposed to be doing something else or in addition to?
Kulebrero is offline   Reply With Quote
Old 03-29-2023, 06:18 PM   #16
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Hold the left button till it changes to track layout. Still won't disable abs.
dragoontwo is offline   Reply With Quote
Old 03-29-2023, 07:14 PM   #17
Ohio Enthusiast
Drives: 2018 BRZ
That's Track Mode, which has less traction and stability control activation but still has some. This might explain the brake overheating.
Ohio Enthusiast is offline   Reply With Quote
Old 03-29-2023, 08:30 PM   #18
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
For the OP if you have something like an aim solo dl2 you can log brake pressure.
Assuming you don’t hit the brake and throttle at the same time you can probably easily see if the brake is being applied without you touching it aka from the traction control. You would also probably have the tc light flash as well
autoracer86 is offline   Reply With Quote
Old 03-29-2023, 08:59 PM   #19
Kulebrero
Drives: GR86
Do have an AIM solo 2DL…might be worth checking to see if it’s applying brakes when I’m on the throttle through turns. Good idea!
But Mike from CSG doesn’t think there are signs of ABS abuse on the rotors. Not sure what that’d look like, but he knows his stuff.
Old 03-30-2023, 04:11 AM   #20
autoracer86
Drives: Toyota GT86
It’s also just fun to look at data lol. I have a tab just for viewing when the traction control comes on.
I’m not sure if over heating the brakes do to over usage would show the same wear as abs abuse. Bit out of my depth on that. Hopefully you see something helpful in the data at least
Old 03-30-2023, 09:58 AM   #21
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Does anyone have any experience with Paragon 4 or 6 pot brake kits? Floating rotors etc, seems like quality stuff. Alcon re-brand? but nicer calipers? A little cheaper than Essex AP if you want a bigger rotor.
fredzy is offline   Reply With Quote
Old 02-09-2026, 10:05 AM   #22
Ardi
Drives: 2013 Subaru BRZ
Brembo Pista, GT, GTS, GTR kits.
6UL will not clear any of the large kits. You will need 18" or very, very specific 17" wheels. Barrel clearance is a challenge when your BBK is serious.
I can get you set up with a complete solution.
Will the Brembo GTS kit work with a TE37 SL 18x8.5+45?
Ardi is offline   Reply With Quote
Old 02-09-2026, 01:40 PM   #23
Yes. May need a spacer depending on the face you have. Not a big deal.
Old 02-09-2026, 09:07 PM   #24
Ardi
Would brake bias be greatly affected if the 6 piston GTS is installed at the front and keeping the rear stock? Or should I opt for the 4 piston kit if rear will be kept stock?
Old 02-09-2026, 09:28 PM   #25
I have no idea which specific GTS kit you have, so I unfortunately am unable to advise. You'll need to ask whoever sold you the kit for technical details and support.
Sumitomo 4 Piston WRX caliper upgrade GC GTS Aero Kit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-06-2020 09:55 AM
OEM Brake Caliper Piston Size Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 08-12-2019 10:07 PM
Caliper paint recommendations? Brink Cosmetic Modification (Interior/Exterior/Lighting) 17 03-16-2018 12:14 PM
Front Brake Caliper Piston Rebuild? smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 10-17-2013 05:18 PM
BRZ Piston Pictures AVOturboworld Engine, Exhaust, Transmission 12 07-06-2012 06:16 PM
