Old 11-01-2012, 08:53 AM   #1
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Sumitomo 4 Piston WRX caliper upgrade
Hi All I was told today that the early 4 Piston Sumitomo Caliper from 1999-2006 will bolt straight onto the 86 braking system and run with the standard rotor. I picked up some DBA5000 series rotors for a steal and I was thinking of using these as a cheaper upgrade to a BBK.
Has anyone fitted them successfully?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 11-01-2012, 09:10 AM   #2
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
Just like the Brembo's they're going to be on backwards. You're going to have to swap the bleeder over to the other side.
TOMIMOTO is offline   Reply With Quote
Old 11-01-2012, 09:17 AM   #3
GC GTS Aero Kit
Thats ok just got told by the brake shop the rotors and the calipers are identical to 1999 - 2006 WRX and current Subaru Forrester and they should bolt on cause they use the same rotor part and caliper bolt separation
BONKRS for life
Old 11-01-2012, 09:59 AM   #4
Racecomp Engineering
The pistons on these calipers are not staggered, so you don't need to do this (when installed with the bleeders at the top you're still good).
- Andrew
Old 11-01-2012, 10:25 AM   #5
choi0706
Drives: t
interesting...
choi0706 is offline   Reply With Quote
Old 11-01-2012, 10:30 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Andrew
What he said.
However, this doesn't fix the real need for the front brakes IMO.. a bigger heatsink.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-01-2012, 10:36 AM   #7
What he said.
Agreed. You get a lighter, stiffer caliper and shift bias slightly rearwards with these, but not much else. The caliper itself is better but you're not going to reduce fade much at all.These calipers on a slightly larger rotor (maybe LGT rotors) would be neat but I'm talking out of my ass on that one and that'd probably take some custom work.
EDIT: I'm wrong on the bias change, the rear FHI 2 pots shift bias forward. Front FHI 4 pots have no effect on bias.
- Andrew
Old 11-01-2012, 10:47 AM   #8
gmookher
I'm not sure shifting bias rearwards is a good thing for this car either.
Not at all. The factory bias braking is perfect for braking into fast corners IMHO. I cant say I 'need more brake' if the fasctory brake witht he ferrodo setup were to hold up. Slows me down just fine with my tires, I could see with a bigger wheel that being a concern
gmookher is offline   Reply With Quote
Old 11-01-2012, 11:24 AM   #9
nm
- drew
Old 12-06-2020, 06:59 AM   #10
marco_mc22
Drives: Toyota 86
Are these the same as the Wrx Pro ones? Piston size 37mm (1.45in) right?
marco_mc22 is offline   Reply With Quote
Old 12-06-2020, 09:55 AM   #11
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I have them and the rears as well, done for the sake of making it faster to swap out my street and track pads. In terms of feel, bite is slightly better and feels easier to modulate pressure. The front are 4 pistons, the rear are 2. Need to use a KNS version 2 bracket for the rear, front bolt on.
malubawla is offline   Reply With Quote
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
Brake piston sizes coyote Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-25-2012 05:51 PM
BRZ Piston Pictures AVOturboworld Engine, Exhaust, Transmission 12 07-06-2012 06:16 PM
Pics: FR-S to get 86 piston badge WhiteGDB Scion FR-S / Toyota 86 GT86 General Forum 60 11-30-2011 12:54 PM
