Old 02-14-2023, 08:20 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
That’s interesting. It’s the first time I’ve ever heard of a manufacturer advocating using an impact to install a nut or bolt. I’ve installed a fair number of shocks an struts. I’ve always found the indexing feature (Allen socket, or wrench flat, or whatever) to be up to task of keeping the shaft from spinning. Removal is a different animal. Impact almost always there.
Of course, I personally have no use for spherical bearings on my street cars and have never used them. My question for you guys that have and are using them is:
Is it really all that different? What’s the torque spec you’re trying to get to?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-14-2023, 08:42 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have it written down on my tool box at home. It's not that tight, like 15ftlb. I think the nuts on the verus hats I am using now are aluminum even.
Old 02-15-2023, 08:37 AM   #17
Racecomp Engineering
Most manufacturers don't because they're worried people will break the shaft, which can and does happen!
Issue here is the adjuster allen at the top of the shaft should not be used to hold the shaft steady. It'll break.
- Andrew
Old 02-15-2023, 08:45 AM   #18
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Shock nuts are literally the one nut on the entire car that I've given up torquing properly to spec. While I refuse to use an impact on it, I've found that torquing it "as hard as I can with a wrench by hand" seems to be the only way I've found to tighten them enough that they don't wind up backing off over time and start clunkety-clunking.
I'm a skinny guy anyway, so it's not like I'm managing 200 ft-lb or anything with all my "muscles."
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 02-15-2023, 09:29 AM   #19
redlined600
redlined600's Avatar
Drives: Fr-s
- Andrew
My T2s have a hex at the top of the shafts (not the adjuster) is this not the case anymore? I just use a through socket and a deepwell socket to tighten them.
Old 02-15-2023, 09:56 AM   #20
That is there...I was talking about people using the adjuster allen to keep the shaft steady (which is a very bad idea) because it looks like the allen on the stock struts.
- Andrew
Old 02-15-2023, 10:04 AM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Fronts call for 26ftlb. Rears are 2 nuts at 15ftlb. I used oem top mounts at the rear. For the front I wanted something with additional caster and camber, and the products that provide that are typically spherical mounts.
I tightened the fronts to 20 ftlb with a 9mm socket on the torque wrench, set in reverse to hold the shaft using the exterior profile of the top of the shaft, and a 17mm box wrench on the nut, which is what I actually turned. I think 20ftlb is getting towards the maximum a typical 9mm bolt head can handle iirc, so I was cringing the whole time lol. I may hit it with an impact when on the car, but it doesn't seem like it's going anywhere. Note, I think this method my not be recommended by @Racecomp Engineering due to past experience with these breaking. Andrew at RCE was pretty great in answering my questions.
Rears were actually pretty easy, I just had to counter torque the top mount and the shaft didn't spin.
I had a really hard time getting the strap wrench method to work. I just couldn't get anything to hold the shaft up to the spec torque. Might be because I have a crappy strap wrench, but the material was just pilling off the strap.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 02-15-2023, 11:23 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
I think it comes down to experience and comfort. I don't rattle the nut on, I run it down slow and then give it a couple short whacks. Then I will double check tightness by hand the conventional way.
Old 02-15-2023, 11:29 AM   #23
100%. And when making recommendations for a broad range of people with different experience levels...the safest way is the recommendation to make, even if it's a little bit of a pain.
EDIT: and to be clear, I personally do not and will never use air tools in assembly of a coilover.
- Andrew
Old 02-15-2023, 01:26 PM   #24
jflogerzi
jflogerzi's Avatar
Good convo everyone. Thank you for inputs
2013 Series 10 FRS #553
Old 02-15-2023, 02:15 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
I help write manuals and service documents for work as well as our service video's, I know the struggle. There is what you would do, and how you need to explain how to do it. I get the luxury of being a guy on the internet who can just give "spit on it and punch it" as advise in this case
Old 02-16-2023, 05:24 AM   #26
bdtbdtbdt
Drives: 2015 Scion FRS
I could not get a rubber strap wrench to hold the shaft from spinning while torquing the top nut. Instead, I wrapped the shaft with 3 layers of good quality duct tape and then tightened a hose clamp around the tape, then vise grips barely snug around the hose clamp. worked great. Be extremely careful not to mar or scratch the shaft
bdtbdtbdt is offline   Reply With Quote
Old 02-16-2023, 09:22 AM   #27
Capt Spaulding
Persona Non Grata
- Andrew
I’ve never had adjustable shocks on a car. I do understand the problem. But from what others are writing I’m guessing there are other ways to torque them down. 26 lb ft isn’t all that tight. The front hub nuts on my PU are speced at 300. And yes, I have a 400 lb ft torque wrench. I have used it exactly twice.
I just have a serious aversion to using impact tools to assemble anything and was (and remain) surprised to see a manufacturer recommend it.
Tein CSG FLA pillowball bearings replacement nkobns Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-16-2021 10:52 AM
LCA PillowBall Joint Rubber Cover Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2016 02:01 AM
FS: Beatrush PillowBall Mounts (Front) Rabbit86 Canada Classifieds 2 08-24-2015 09:14 AM
Pillowball trailing and control arm bushings? Proof Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-17-2014 06:23 PM
Pillowball or urethane for lca / uca diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-23-2013 11:40 AM
