#15 | |
Flex fuel reads content, so.... ask your tuner for an opinion. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Olson1288 (10-10-2022), x808drifter (10-11-2022) |
#16 | |
Drives: 2014 DGM BRZ Turbo
Appreciate the response and you taking a look man. The car has ran great with no changes to the tune for roughly 2 years now. I haven't changed any components on the vehicle either, so I'll just tear into it tomorrow and start checking everything I can.. maybe a bad exhaust leak somewhere, o2 sensor, not sure anymore. If all else fails I'll contact the tuner and see if he can possibly shed some light. |
#17 |
Just a small update. Here we are months later, I still have yet to figure out what this issue with the accelerator pedal is. I have replaced coil packs, replaced the entire throttle body/sensor. Checked for any vacuum/boost leaks. Checked for exhaust leaks. Car still throws zero codes. Issue essentially remains the same: car will drive fine for a while, then after sitting for an hour or 2, accelerator pedal will randomly stop working while driving, as if it has like 5% input or nearly total fuel cut. Car will die when coming to a stop after this happens, and hesitates to start/idle again. Can get the car idling again, but it will run extremely rich after that, but I can limp it home/to my destination.
I would have probably just taken to some sort of reputable tuner shop by now but that doesn't exist fit my current financial situation but will possibly look into it.. I've loved this car for almost 8 years now, but if I can't fix it soon, it may just be time to move on. |
| The Following User Says Thank You to Olson1288 For This Useful Post: | x808drifter (02-21-2023) |
#18 |
Big thank you to @tomm.brz. He managed to take a look at some data logs and determined it was a bad map sensor that was causing my issue. Replaced it and car hasn't skipped a beat since. Just wanted to post a thanks and also leave this here for anyone running into this issue possibly in the future.
| The Following 8 Users Say Thank You to Olson1288 For This Useful Post: | alphasaur (02-28-2023), DarkPira7e (02-28-2023), Joveen (03-01-2023), MICHAEL450f (02-28-2023), RToyo86 (03-07-2023), T-Steve (02-28-2023), tomm.brz (02-28-2023), Wally86 (03-01-2023) |
#19 | |
Drives: WRB BRZ
| Strange electrical issue | Sniepster | Issues | Warranty | Recalls / TSB | 14 | 11-20-2020 09:54 AM |
| Strange light issue | DubLord | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-03-2018 08:25 PM |
| Strange Smell after Driving | ThisGuyRett | Issues | Warranty | Recalls / TSB | 31 | 10-12-2016 05:17 AM |
| Strange reverse issue | fanaticalz | Issues | Warranty | Recalls / TSB | 12 | 04-14-2016 03:33 PM |
| Strange acceleration issue | mhughett | BRZ First-Gen (2012+) — General Topics | 11 | 03-16-2016 11:40 AM |
