Old 04-13-2016, 04:42 PM   #1
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
Strange reverse issue
I just installed a clutch + flywheel, and now my backup camera and gear indicator on the dash isn't showing reverse (but it shows 1-6). Instead, the gear indicator shows that I'm in 1st when I'm actually in reverse.
The reverse gear itself works with no issues, and my reverse lights are working.
Here's where it's a little weird. I started the car up once, put it in reverse, and the backup camera came on for a second, then disappeared. So the signal is there, it's just losing it it seems. The backup camera only worked once out of 10 or so times.
I'm not actually sure if this was caused by the clutch install, because I don't know if it was working after the fact or not - I just noticed it the other day. It may have just happened on it's own, randomly.
Anyone have any ideas?
fanaticalz is offline   Reply With Quote
Old 04-13-2016, 05:09 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
@humfrz @Tcoat any ideas on this, I am trying to figure wth could cause his issue (only thing I can think of is electrical, but how one would fck up electric systems while doing a clutch install is beyond me) but am coming up empty (and now it bothers me not to know)
fumanchu1 is offline   Reply With Quote
Old 04-13-2016, 05:11 PM   #3
Cole
Not a troll
Cole's Avatar
I'm going to hazard a guess at
A) You blew a fuse
or
B) You knocked the reverse gear sensing wire loose enough that it manage to stay connected for a second, until you shifted into reverse and that was enough to knock it fully out of place (though, I will admit I don't know if that's a thing or not)
Old 04-13-2016, 05:14 PM   #4
Moved the shifter sensors around when tranny was off to install flywheel. Not an uncommon thing to happen actually. That is why it flickered once. Probably very close and shouldn't be to major a job to adjust.
Old 04-13-2016, 05:45 PM   #5
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
Are those underneath the shifter? I don't need to remove the tranny again? I had a shop do the install so I've never actually messed around with the shifter linkage or anything.
Old 04-13-2016, 06:11 PM   #6
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
Ok, I figured something out.
It does show reverse, and the backup cam does work, BUT the issue is that when I put it in reverse, it goes "too far in". If i hold the shifter in reverse, but pull down a bit (towards center), it will work.. so it's going too far in.. linkage problem?
Old 04-13-2016, 06:14 PM   #7
Linkage or the switch may be misaligned. Take it back to who did the work and make them fix it.
Old 04-13-2016, 06:45 PM   #8
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
They're saying it's not adjustable so it couldn't be misaligned, but they'll look the shifter plate.
Do you think the clutch itself could be causing this type of issue? Letting the gear go in too far? I don't think that's possible though. Or maybe it's not going in too far (it seems to go in just as far as 1st gear, I have to pull it back about half an inch to get it to "work"), there's just a problem outside of the shifter?
Old 04-13-2016, 06:51 PM   #9
Nope the clutch only engages the power to the tranny and would not cause that. They simply have something misaligned just a small bump could do it. The very fact that you can pull it back and make it work means that something is out of place.
Old 04-13-2016, 08:44 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
See the image. The white cable running on top of the transmission, leads to a sensor on each side (one of them is the reverse sensor). I broke one off and did not have a reverse signal at all. I wonder if the sensor is loose on your transmission and thus it works if you pull the shifter a certain way.
Old 04-13-2016, 09:07 PM   #11
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
Thanks @Tcoat - I fixed it. I looked at the shift plate and reverse lockout plate. I moved them slightly to the left, and I also put my hand down with the shift linkage and kinda just wiggled it all over the place. Somehow, that worked. I don't know what specifically fixed it, because nothing looked out of place.
Hopefully this helps someone down the road.
The Following User Says Thank You to fanaticalz For This Useful Post:
Tcoat (04-13-2016)
Old 04-13-2016, 09:10 PM   #12
Good!
Figured it was something basic when you could get it to work by pushing on the lever. Be great if everything was that easy.
fanaticalz (04-13-2016)
Old 04-14-2016, 03:33 PM   #13
fumanchu1
Good!
I knew getting the "seniors" in here would prove useful
The Following 2 Users Say Thank You to fumanchu1 For This Useful Post:
fanaticalz (04-14-2016), Tcoat (04-14-2016)
Strange issue in steering or possibly clutch? Renesis Issues | Warranty | Recalls / TSB 14 05-11-2019 05:10 PM
Strange acceleration issue mhughett BRZ First-Gen (2012+) — General Topics 11 03-16-2016 11:40 AM
LED Switchbacks strange issue theparagon Cosmetic Modification (Interior/Exterior/Lighting) 21 07-31-2014 02:21 PM
Manual Trans (Reverse Issue) mxrcmxlendon Engine, Exhaust, Transmission 1 02-24-2014 11:18 PM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 09:05 PM
