Old 12-03-2018, 12:40 PM   #1
DubLord
Strange light issue
My driver side yellow fog/blinker light doesnt work... sometimes. When I turn on my headlights it doesnt light up, as if I have a bad bulb or something. But when I use my turn signal it will blink properly. Any ideas on what my issue could be? Hopefully my post makes sense
Sent from my SM-G955U using Tapatalk
DubLord is offline   Reply With Quote
Old 12-03-2018, 03:46 PM   #2
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
You could try replacing the bulb and seeing if that fixes your problem.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 12-03-2018, 03:52 PM   #3
DubLord
Your right I'll get one from the dealer
Old 12-03-2018, 08:14 PM   #4
highway7
Drives: FRS 2013
The turn signal bulb actually consists of two filaments
A low power filament for the running light when you have the parking lights or headlights on
A high power filament for the turn signals, hazards, and "flash" when you lock the car with the remote
So basically in your situation, the low power filament has burned out but the high power filament still works.
Solution: Change light bulb.
highway7 is offline   Reply With Quote
Old 12-03-2018, 08:25 PM   #5
DubLord
Thanks for the explanation!
Strange issue in steering or possibly clutch? Renesis Issues | Warranty | Recalls / TSB 14 05-11-2019 05:10 PM
Strange Rear Suspension Issue dvniemela Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-28-2018 09:35 PM
Strange reverse issue fanaticalz Issues | Warranty | Recalls / TSB 12 04-14-2016 03:33 PM
Strange acceleration issue mhughett BRZ First-Gen (2012+) — General Topics 11 03-16-2016 11:40 AM
LED Switchbacks strange issue theparagon Cosmetic Modification (Interior/Exterior/Lighting) 21 07-31-2014 02:21 PM
