This Guy
Drives: 2015 Halo FR-S M/T
Strange Smell after Driving
Hello all,
I have 6mt 2015 FRS with about 19k miles on the odo. After driving for periods of 30mins or longer, i get this strange smell coming from the engine bay. It is not the clutch. I know what burnt clutch smells like. This smell is more of a "hot burnt plastic/rubber" smell. No issues with my camplate. This smell makes me question my driving ability with the manual transmission, but I have been driving manual for years. I have owned this FRS for about 3 months now and I want to know if this normal or not. Thanks in advanced guys. P.S. - I have done a ton of research but I have only found threads on the earlier production models and they were new. Photo for attention
hey you, yeah you <3
Drives: 2014 37J FR-S
Is it strong chemically? May be engine cleaner. I took to dealer, they spilled oil, used degreaser/cleaner and 2k miles later smell didnt go away, so I just sprayed my engine bay down twice. Went away after 20min of driving.
#3 | |
Is that smell normal ?...... well, my FR-S doesn't smell that way. Does your car have any power mods ..?? So, you have ruled out a possible leaking cam plate .......hmmmm ...... what about the timing chain cover or oil dip stick "O" ring leaking down onto the exhaust heat shield ..?? You might feel your front wheels after driving for a spell, to make sure you don't have a front brake pad dragging... ?? humfrz |
Huge E85 fan!
Drives: 2016 Scion FRS
start your search around the exhaust header, it's the hottest part of the engine compartment, it could be something that got int there off the road or a fluid.
#5 | |
This Guy
Sent from my SM-N920V using Tapatalk |
you doing burnouts and powersliding your car around too much?
Drives: Subaru BRZ
#9 | |
This Guy
As for the front brakes, there is no dragging from what I can see. I'll check next time I drive if the smell is stronger around the brake area. Sent from my SM-N920V using Tapatalk |
#10 | |
This Guy
#11 |
Drives: car
@ThisGuyRett Even if there's no visible spots on the header, check for oil leakage under the passenger side engine timing cover, use a paper towel and swipe on the underside, it's an angled piece that sticks out a a bit.
#12 |
Drives: GT86
Maybe the green wax they put on the engine bay when shipping oversea?
#13 |
This Guy
#14 |
This Guy
| Nightmare driving FR-S vs driving Miata | chrisngn | FR-S / BRZ vs.... | 64 | 07-06-2016 11:21 AM |
| Does anyone else occasionally smell a burning odor during cold weather driving? | Meanderchap | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-10-2016 02:10 AM |
| 2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while | hosfordbrandon | Issues | Warranty | Recalls / TSB | 46 | 11-02-2015 02:42 AM |
| Anyone else notice a strange smell?? | Bigedb | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 07-19-2013 12:43 AM |
| strange smell - kerosine | karlos13 | AUSTRALIA | 7 | 08-20-2012 12:50 AM |
