Old 09-22-2022, 12:24 PM   #15
WNDSRFR
Drives: FR-S,GTI
Ok, first maybe you could clarify what you know about the history of the car. You said in another thread you bought is with 43km, then first post of this thread you said you bought it in 2018 and now has 85km?
So did you buy it in '18 with 43km, and you've driven it to 85000km? If this is true, with no service other than oil changes, I would:
Have brakes inspected, replace pads and rotors if needed, replace brake fluid.
Service transmission. (AT or MT)
Service rear end.
Flush cooling system. Replace with proper anti-freeze. It's early mileage wise, but car is almost 10 year old, so I would do.
I'll assume you are changing air filter at proper intervals?
CGS has a good link to give you an idea of maintenance needs
https://www.counterspacegarage.com/b...86-subaru-brz/
Thanks for the reminder. I guess I should clean my air filter. Last time I did that was at least 100,000 miles ago.
Old 09-22-2022, 12:57 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by WNDSRFR View Post
You're kidding me! Every 30K miles?
That means I should have changed it 7 times by now.
I've changed it 0 times. Added a little fluid once because it was a little low. I added about a bottle caps full. Brakes work fine.
Old brake fluid is very bad for master cylinders and calipers. Easier and cheaper to change fluid than replace a sticky caliper.
Old 09-22-2022, 03:39 PM   #17
WNDSRFR
Drives: FR-S,GTI
OK
You're right. I should do that too.
I'll get around to it the next time it's not hot as hell or raining.
Old 09-22-2022, 04:24 PM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
OK
Another 100,000 miles in Florida.
Old 09-22-2022, 05:36 PM   #19
Ultramaroon
not playing cards
Ultramaroon's Avatar
More than anything, it's the only way to gauge the internal health of your brakes. When you bleed them, don't expect to get any air. If you do, that's a red flag. Look for a corresponding increase in pedal stiffness. This is why I don't like the vacuuming types of bleed kits. I want to hear/feel the crackle of any air released under pressure the first time I slowly open the valve. If there isn't, I'm a happy camper.
Then look at the condition of the captured fluid. If it's shitty, keep bleeding until it looks fresh. Stay on top of the fluid in the reservoir. It's a bad day if the master cylinder sucks air.
Old 09-22-2022, 07:48 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I flush mine yearly
Reminds me, need to do my truck.
Old 09-23-2022, 03:51 PM   #21
droopynips
droopynips's Avatar
Drives: 2013 FR-S heavily scratched bumper
So my friends, it appears to me that the mechanic said i just need to top up my fluid as it is swishing at stops and triggers the sensor. It is currently right at the min line, what level do you lads keep yours at? Do I need to wait for the engine to cool fully to place the new fluid?
Thank you friends
droopynips is offline   Reply With Quote
Old 09-23-2022, 06:26 PM   #22
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Thank you friends
Mine continually goes up and down. So I keep it no lower than minimum and no higher than maximum. This is where the system is designed to operate safely and correctly. The minimum level giving you warning, not usually triggering the light.
gen3v8 is offline   Reply With Quote
beginner, brake, newbie, oil, scion
Brake Fluid Flarpswitch BRZ Second-Gen (2022+) — General Topics 5 03-14-2022 08:35 PM
topping off oil for track days? evanescent03 Tracking / Autocross / HPDE / Drifting 21 03-03-2022 07:44 PM
Brake fluid allowe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-16-2020 11:38 AM
Jelly in brake fluid smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-05-2016 04:08 PM
Topping off coolant with Peak 50/50 Astroboy Engine, Exhaust, Transmission 4 12-04-2014 02:00 AM
