Old 12-03-2014, 08:17 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Topping off coolant with Peak 50/50
So a Couple years back I remember looking at my coolant reservoir tank and noticed it was slightly below the low. Little did I know that coolant expands when the car is warm, and my car was still cold.
Anyways when I thought it was low, I topped it off with some peak 50/50 antifreeze; the antifreeze that apparently can mix with any other coolant.
After reading the consequences of mixing any other coolant with the factory blue coolant my anxiety kicked in.
Should I be worried? My water temp never gets any higher than 100 Celsius and I'm turbocharged.
Astroboy is offline   Reply With Quote
Old 12-03-2014, 10:48 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Wouldn't hurt to flush the coolant system and add fresh coolant.
JDKane527 is offline   Reply With Quote
Old 12-03-2014, 11:57 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
I'll do that then. Just hope I didn't damage anything like from corrosion or something.
Old 12-04-2014, 12:53 AM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Never mix with other brand. I would go local Subaru/Toyota dealer than get few bottle of blue coolant and flush it out JIC
...but that's just me
Old 12-04-2014, 02:00 AM   #5
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Don't worry too much about it. All newer antifreeze are compatible, regardless of color, with only small changes to corrosion inhibitors. Newer NOAT and OAT coolants are getting ratings of up to 15 years of service life based on the amount of these inhibitors added to the antifreeze. They all have ethylene glycol base, but a lot of manufacturers list their corrosion packages as "proprietary ingredients", which, just like oil manufacturers, they don't have to disclose.
But I'd highly doubt a failure to come from adding in a bit of PEAK for topoff. As long as it is the long-life variant, you should be just fine.
Coheed is offline   Reply With Quote
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Pikes Peak Hill Climb swift996 Scion FR-S / Toyota 86 GT86 General Forum 11 06-29-2013 04:38 AM
Anyone going to Pikes Peak? stocktc1 Off-Topic Lounge [WARNING: NO POLITICS] 6 05-06-2013 05:57 PM
NA Peak torque PowderfaceTr. Forced Induction 7 04-24-2013 09:41 AM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
