Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 10-22-2022, 01:12 AM   #15
gcmak
gcmak's Avatar
Drives: GR86
Originally Posted by chinee View Post
Only 600 mileson the oil? You didn't change the oil right? Just drew some out of the dipstick? Why such a short interval?
I did change the oil and filter. My car is better set up since the last oil change to run sustained hot laps in HPDE. It saw 3 HPDEs with oil temps sustained ~260F and ambient at or above 100F. Seeing the results gives me a bit more confidence to know that the oil and engine isn't failing as a result of running in those conditions. Unsure how the differential and transmission are doing.
To add, the previous analysis was 4 HPDEs, 3 of those were 100F+ days but the car didn't have tires that could hot lap, especially not in such hot temps, so while oil could hit 263F, it wasn't sustained as I needed 1-2 cooldown laps for every hot lap.
gcmak is offline   Reply With Quote
The Following User Says Thank You to gcmak For This Useful Post:
Petah78 (10-22-2022)
Old 10-22-2022, 01:54 AM   #16
loungin
Drives: 22 gr86
What oil are you using for hpde?
loungin is offline   Reply With Quote
Old 10-22-2022, 09:04 AM   #17
Petah78
Drives: 2022 BRZ sport-tech
Thanks for the detail info. Did you ever had your pick up inspected? If so, how bad was the blockage, if any?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 10-24-2022, 01:36 AM   #18
gcmak
gcmak's Avatar
Drives: GR86
5w30. Not married to any brand in particular. I've had Mobil1 and Motul 8100 analyzed. non-scientifically the numbers for Motul 8100 look better, but both oils are within spec after use.
Thanks.
Never inspected. Confident there's a RTV in there. If I open things up, it'll be some combination of a confirmed problem from the OEM, i'm adding a baffle because the data being gathered by people much smarter than me show a consistent and significant drop in oil pressures on track, or the thing blows up.
Petah78 (10-24-2022)
Old 10-24-2022, 12:02 PM   #19
Petah78
Thanks. Please do post the state of your pick up when you install your baffle.
Old 04-25-2023, 02:51 PM   #20
Petah78
My contribution,
2022 BRZ with 3100 miles on the odo. Easy break in with the original oil and filter changed out at 1000 miles. The UOA was done on oil that had about 1800 miles on it.
Brand: Pennzoil Ultra Platinum
Grade: 5W-30
Mileage on oil: 1800 miles/9 months (car was parked over winter)
Mileage on engine: 2800 miles
I think the results are inline to what others have posted. The high wear metals is from break in and should calm with subsequent oil changes.
The Following User Says Thank You to Petah78 For This Useful Post:
gcmak (05-02-2023)
Old 07-31-2023, 07:30 PM   #21
gcmak
gcmak's Avatar
Drives: GR86
Final oil analysis results arrived for my 2022 GR86 Automatic.
17 events total on the motor, mostly HPDE and a few AutoX/Drift events in between.
Sold with 6,900 Miles in July 2023.
The Following 4 Users Say Thank You to gcmak For This Useful Post:
DarkSunrise (08-07-2023), Petah78 (08-01-2023), Wally86 (07-31-2023), ZDan (08-03-2023)
Old 08-02-2023, 07:27 PM   #22
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I love a good UOA and always have gotten one, keep cars well maintained and maybe some luck. My question for everyone is what would you do if you got a bad one other than save for a new engine. Would you really baby it, or dump it off for the next guy.
I only do the UOAs at major milestones like 50k, 100k etc.
Ernest72 is offline   Reply With Quote
Old 08-03-2023, 05:06 PM   #23
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
That’s the exact logic of why I wondered one care to even do this?
It’s one thing if you have a race engine that you have 10,000’s of dollars invested in to potentially salvage a catastrophic failure that would net 10000’s of dollars in loss.
Then doing this test with vehicles that are either warranted or are low in cost why would you worry? Change the oil regularly as scheduled… if you track it cut that in half. Seems silly to bother. I’m waiting for someone to laminate an oil analysis for a car show. ��
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 08-03-2023, 06:47 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
It's $35, short $$. I'm doing it to see if I'm getting excessive wear metals in the oil, if I am I'll probably quit tracking it until I get an accusump and/or proven-effective baffle. If analysis of oil that has 4 track days at right-hander intensive tracks looks good, I will proceed and not worry, and probably not get another analysis done for a long time.
Old 08-03-2023, 06:51 PM   #25
vindiesel
vindiesel's Avatar
How can you differentiate normal engine wear, high engine wear, engine will grenade at any time? Educate me seems subjective from an oil analysis.
Seems like doing this just puts people into cyclical worry regardless.
Old 08-03-2023, 06:58 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
Blackstone provides commentary on whether wear metals are normal or excessive.
I don't expect results to be absolutely predictive of engine durability while tracking. It's just an indicator. I won't go into "cyclical worry" either. If wear metals are high, I'll either quit tracking it or minimize number of stints and laps per stint until I take measures. If wear metals are "normal", I'll continue tracking it going out every stint.
I'm curious to see if the oil has normal or excessive levels of wear materials after a few track days, and it only costs me $35 for this one snapshot. No big deal...
vindiesel (08-03-2023)
Old 08-06-2023, 02:53 PM   #27
Ernest72
Tracking a car, a UOA will have some useful info. For a DD, it’s just a check and see where you stand. I would not be doing it at 1000 miles.
Old 08-06-2023, 04:07 PM   #28
Ultramaroon
not playing cards
Ultramaroon's Avatar
Early UOA will reveal an issue with build quality well before the engine actually fails. High wear metals? Don't drive far from home. Consider next steps.
A couple healthy reports? Relax and have fun with it.
Petah78 (08-07-2023), Teseo (08-06-2023)
Post Recall Blackstone Report marco1ca Issues | Warranty | Recalls / TSB 23 09-23-2019 11:06 PM
Blackstone Used Oil Analysis (UOA) Mobil 1 Extended Performance 0W-20 chipmunk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 09-18-2018 08:58 PM
Blackstone Oil analysis at 52k/45k/37k strat61caster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-06-2017 01:26 PM
First oil analysis report acx23 Northern California 5 07-27-2015 01:25 PM
