Old 09-07-2018, 01:10 PM   #1
chipmunk
Drives: _
Blackstone Used Oil Analysis (UOA) Mobil 1 Extended Performance 0W-20
At the time of the test, car had 34500 miles overall, the oil had about 3400 miles. Engine is stock. Just throwing it out there for anyone interested in info on Mobil 1 EP.
I'll probably have UOA done every 30k miles or so, just to track the general health of the engine.
By the way, is there a compilation of all UOAs on these forums?
chipmunk is offline   Reply With Quote
The Following 3 Users Say Thank You to chipmunk For This Useful Post:
Bonburner (09-07-2018), dhuang (09-12-2018), MCTeeJ (09-12-2018)
Old 09-12-2018, 03:40 AM   #2
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
I also use 0-20W Mobil 1 (Advanced Fuel Economy)
Just sent Blackstone my sample at 23k miles. I am also concerned about oil consumption -- we'll see what they have to say.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 09-12-2018, 08:57 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
With regards to oil consumption, last I checked my oil it had been over 8,000 miles since my last oil change and it was still just shy of the full mark, with ZERO oil added since that oil change. And my BRZ has 63,000 miles on it. #winning
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-12-2018, 09:21 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I posted my UOA after 10k miles of Mobil1 (did not add any oil) and the results were fantastic, TBN was great as well.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-12-2018, 09:29 AM   #5
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
I actually just switched back to this oil after running Motul 5w30 for a year or so. Wanted to go back to 0w20 and was due for a change so I just went to Walmart for supplies this time. Might shop around with Amsoil or Schaeffer's next time, but I'm glad to see this oil still suits the engine fine. I have noticed the consumption myself as well though.
MCTeeJ is offline   Reply With Quote
Old 09-13-2018, 07:37 AM   #6
chipmunk
Drives: _
I do plan on switching to 5W-20 (wife's car calls for 5W-20, so I figured it's easier to buy the same stuff for both cars).
When I used 0W-20 for both cars, her car used up more oil than usual.
Old 09-13-2018, 08:22 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Makes sense, thinner, less viscous oil burns faster.
Current DD: M235i
Old 09-15-2018, 11:03 AM   #8
gravitylover
I barely burn any oil at change time which is usually around 7k with 105k on it now. #alsowinning
The Following User Says Thank You to gravitylover For This Useful Post:
chaoskaze (09-15-2018)
Old 09-18-2018, 07:58 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Same boat as you guys, no oil burning here either. Running e85 by the way so my change intervals are 4500-5500 miles and they haven't dropped past the full mark. I've been using Eneos 0w20 off amazon.
Blackstone determines the best oil brand Buffalo_Rob Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 08-06-2017 05:32 AM
Blackstone Oil analysis at 52k/45k/37k strat61caster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-06-2017 12:26 PM
Which oil filter to pair with mobil 1 extended performance engine oil? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-17-2016 12:21 AM
Mobil 1 0W-20 Brahsbrah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 109 07-01-2014 09:29 PM
