Old 09-19-2019, 07:50 PM   #1
marco1ca
Drives: Toyota Celica
Post Recall Blackstone Report
So I didn't post this in "failure" thread or "no failure thread" as I"m not sure yet.
'13 BRZ, 1800 mi. post recall work. Just received oil analysis report (attached)
and could use input on the silicon level. Silicon level states "63" when the average is '26'.
Here's what I don't understand; I spoke with analysis from Blackstone who said this is normal for an engine that just had this type of recall work. I explained to him that too much sealer has been linked to the cause of many engines blowing up. He hadn't heard of this but is now researching it. He also said that brand new vehicles from factory will test higher levels of silicon than mine, but it should dissipate by the next oil change. Just wanted to share this test result and hear any comments or suggestions, thank you
marco1ca is offline   Reply With Quote
The Following User Says Thank You to marco1ca For This Useful Post:
mswbrz (09-19-2019)
Old 09-19-2019, 08:28 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
It's chunks of the sealer that cause problems, not the stuff that's absorbed into the oil... which is going to be higher after a rebuild such as you get with the warranty work, just as they said.
So, it doesn't really mean much at all in this context; the results should be expected given the work done. Unless there were chunks, it's not an indicator of anything (yet).
The Following 2 Users Say Thank You to cjd For This Useful Post:
marco1ca (09-19-2019), Tcoat (09-20-2019)
Old 09-19-2019, 09:25 PM   #3
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Appreciate you following up with us man so many people reporting they were going to do this but no follow up keep us updated brother thank you
mswbrz is offline   Reply With Quote
The Following User Says Thank You to mswbrz For This Useful Post:
Old 09-19-2019, 09:50 PM   #4
radroach
Drives: car
Doesn't silicon content just mean dirt that may have fallen into the engine when it was opened up?
I changed my oil 3 times in 1000 miles after recall to make sure it was clean.
The Following User Says Thank You to radroach For This Useful Post:
Grady (09-20-2019)
Old 09-19-2019, 10:18 PM   #5
marco1ca
I don't know, but as I said above, Blackstone states there is a higher content of silicon when they are right of the line
Old 09-19-2019, 11:20 PM   #6
radroach
Drives: car
Do two quick OCI's / filter changes and do a follow up report if you've got the scratch.
Old 09-19-2019, 11:53 PM   #7
marco1ca
I have the blackstone containers ready for the next, but, it's like a $100 to change it. I think Subaru should pay for this next oil change.
Old 09-20-2019, 09:42 AM   #8
Why should they pay for your paranoia? The Blackstone rep already explained to you that higher levels would be expected. They just sealed your engine with silicone that had to cure so of course there are higher levels right now. It is not an indication that your passages are blocked in any way.
DarkPira7e (09-20-2019), soundman98 (09-24-2019)
Old 09-20-2019, 09:47 AM   #9
radroach
Drives: car
@marco1ca $100 for an oil change, whew. I think I can do 3-4 oil changes at that price.
You know Mobil 1 ran a rebate this summer right? 5 quarts of Mobil 1 cost me $15 after rebate.
Old 09-20-2019, 10:58 AM   #10
Grady
Grady's Avatar
Silicon is not Silicone.
Check intake filter/system and PCV system.
They are not dong this recall work in a clean room and most technicians are probably not cleaning the parts prior to reassembly.
The Following User Says Thank You to Grady For This Useful Post:
marco1ca (09-20-2019)
Old 09-20-2019, 12:34 PM   #11
I just can not wrap my head around the fact that this is even being discussed. Why bother to have a test done if you can't believe the report?
Grady (09-20-2019), gravitylover (09-25-2019)
Old 09-20-2019, 01:45 PM   #12
marco1ca
Tell that to the owners whose cars blew up.
Old 09-20-2019, 01:47 PM   #13
marco1ca
Thanks, I didn't check before I had it done, mistake
Old 09-20-2019, 01:50 PM   #14
marco1ca
Bullshit! They caused the paranoia by forcing Californians to do an otherwise unnecessary recall.
How long is too long for post-recall repair? ndsleep612 Issues | Warranty | Recalls / TSB 2 08-04-2019 05:35 PM
HORRIBLE GAS MILEAGE POST RECALL (ಥ﹏ಥ) ¯\(°_o)/¯ mswbrz Issues | Warranty | Recalls / TSB 14 08-02-2019 05:38 PM
Loud ticking post recall fix Outlander Issues | Warranty | Recalls / TSB 27 07-16-2019 12:11 AM
She lives once more! (post-recall damage) BlackOptics Northwest 9 03-22-2019 06:53 AM
