Old 08-19-2012, 01:02 AM   #15
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
You have 3 options
1- For the perfect look would be Front 18x8 +48, Rear 18x8 +35
2- 18x8 +35 all around is easer if you rotating the wheels in the future, and could be better in handling
3- 18x8 +48 all around for safer fitment
adprokid is offline   Reply With Quote
The Following 2 Users Say Thank You to adprokid For This Useful Post:
BRZranger (08-19-2012), calis5nest (08-19-2012)
Old 08-19-2012, 03:15 AM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by brzranger View Post
You know, I think I'm worrying too much about .4". Looking at the stickies, 45 looks fine (not perfect) on lowered cars.
And as far as spacers go, sounds like there is a small chance of failure, which is probably unlikely, but not going to take the chance.
Hindsight, I would have got 35, as Norcalscionchamp's setup looks wicked.
Hopefully I didn't thread jack too much!
Just install what you have and if anything get a 10 or 15mm spacer for the back you really won't need it for the front.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
Old 08-19-2012, 03:21 AM   #17
BRZranger
Researching a bit more, a more aggressive offset adds stress to wheel bearings and increases performance by widening the stance. I guess for my purposes, et45 is appropriate. If I hate it, I'll probably get the spacers, I think Eibach makes high end ones. Any recommendations on spacers?
BRZranger is offline   Reply With Quote
Old 08-19-2012, 03:50 AM   #18
JoeBoxer
JoeBoxer's Avatar
Ichiba or Project Kics, H&R if they make some.
Old 08-19-2012, 05:35 AM   #19
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
the problem with running same offset AND width front and rear is taht the fronts will always poke further out than the rear (I suppose Subaru/Toyota wanted to fit the boxer engine in there, so they spaced it out).
You can easily see this on the car stock. If you want to preserve the stock balance that's cool, but if you're looking for stance, you can either run different offsets front/rear or run a wider rear.
That's why I made my suggestion based on the wheel options given.
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
Old 08-19-2012, 08:24 AM   #20
BRZranger
I was looking at this, which is a 18x8et45, not flush but looks pretty nice IMO:
http://www.ft86club.com/forums/showthread.php?t=5749
Is this what I should expect with 45? If so, seems acceptable to me.
Old 08-19-2012, 11:18 AM   #21
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Obviously that is lowered, but yes.
A +35 would stick out 10mm more than that on an 8" wide wheel.
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Old 08-19-2012, 12:47 PM   #22
ebphoto
Drives: FR-S, NA8, S13
Originally Posted by epson1 View Post
Why buy a spacer to get an offset you want when the manufacturer makes the right offset. I have 18x9 +30 and these aren't that aggressive. Just go +35 and be done with it.
they arent made in the "right offset".
most single piece wheels are made in certain offsets because they will fit a whole slew of cars... not vehicle specific.
ebphoto is offline   Reply With Quote
Old 08-19-2012, 03:25 PM   #23
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
For those who wants to run wider wheels with same offset all around, i'm sure later there will be an aftermarket front wider finders.
Old 08-19-2012, 04:14 PM   #24
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
According to the wheel offset chart, 8" wheel at stock height is flush in front at +38, so a +35 would poke a bit. After a 1" drop, +36 offset would be flush. So a +35 is a bit aggressive for the front.
+48 in front and +35 in back should be nice, but I'm not sure the difference is worth not being able to do an easy rotate.
Phaedrus29 is offline   Reply With Quote
Old 08-19-2012, 04:30 PM   #25
ill86
ill86's Avatar
Drives: iG FR-S
It depends on your alignment settings, ride height and tire width.
In other words.. It depends on who you ask. It's another "art" or personal taste vs "correct" or exact.
For instance Volk recommended a slight variation to this forum's wheel fitment thread.
Best of luck!
MarkMash (08-20-2012)
Old 08-19-2012, 05:34 PM   #26
mike2100
mike2100's Avatar
Drives: 23 BRZ
So you can still rotate the tires
mike2100 is offline   Reply With Quote
Old 08-19-2012, 06:09 PM   #27
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
Without a doubt +35. Even that has room to spare.
But whatever you decide to do, keep the same offset in the front and rear. Flush rears with sunken fronts is YUCKY.
BTW, what in the world makes +48 "the safer choice?" +35 isn't even flush, especially when lowered.
Entropy is offline   Reply With Quote
The Following 2 Users Say Thank You to Entropy For This Useful Post:
ill86 (08-19-2012), MarkMash (08-20-2012)
Old 08-19-2012, 07:14 PM   #28
Phaedrus29
Phaedrus29's Avatar
Actually +38 is flush in front (at stock height), so +35 pokes. With a 1" drop, +36 is flush in front, so again, +35 is very slightly over flush.
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
***FORTUNE AUTO COILOVERS*** FT-86 SpeedFactory **EXPERTS** FT-86 SpeedFactory Brakes, Suspension, Chassis 32 09-21-2012 10:42 PM
Lease experts I need help. Liquidsnake Off-Topic Lounge [WARNING: NO POLITICS] 4 05-30-2012 04:21 PM
Photoshop Experts..have a request (BRZ with GT86 Front Bumper) swift996 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 12-06-2011 03:41 AM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
