Old 03-20-2022, 03:28 PM   #15
norcalpb
norcalpb's Avatar
I have the HKS header and it is surprisingly heavy for what it is, but I do like how it’s styled after the OEM header minus the cat.
The Following User Says Thank You to norcalpb For This Useful Post:
RToyo86 (03-21-2022)
Old 03-21-2022, 02:02 AM   #16
gpvecchi
gpvecchi's Avatar
Originally Posted by weederr33 View Post
Well the top one is HKS and it's a decent header. I'm not familiar with the bottom. But I'm sure either or will only net very little difference.
Nope, the top one is not HKS...
gpvecchi is offline   Reply With Quote
Old 03-21-2022, 05:13 AM   #17
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Depends on your goals/priorities. Recognizing both headers...
Header 1 would be the better daily driver. Comes with a catted and resonated front pipe that's known for keeping almost stock noise levels. And as you mentioned, has better low-end torque.
Header 2 seems to be more track oriented given the company's background and as you mentioned, produces more power in the higher RPM. I predict this unit will be louder. Comes with a strange catted HALF front pipe; you chop the OEM front pipe in half and keep the resonator side, then use a slip joint/clamp to connect them. The dinky OEM front pipe resonator isn't the best at keeping noise/drone down, especially compared to the larger resonator that comes in the front pipe of Header 1.
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
gpvecchi (03-21-2022)
Old 03-21-2022, 08:36 AM   #18
gpvecchi
gpvecchi's Avatar
Exactly what I needed, thanks! You discovered the brands, I see... The half front pipe, is for japanese laws, if you replace the resonator of the front pipe, you need to get the homologation for the full exhaust, or you'll have to keep stock cat back.
I'll go with the first one, that's Apex'i. The second one is Revolution Garage.
The Following User Says Thank You to gpvecchi For This Useful Post:
NLSP (03-21-2022)
Old 03-21-2022, 09:41 AM   #19
KillerBMotorsport
KillerBMotorsport's Avatar
Bottom header will perform better IMO. Neither are great, but if you HAD to pick based on design appearance potential, the bottom one has more aspects that would lend it to make better power.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
Espi (03-21-2022), gpvecchi (03-21-2022)
Old 03-21-2022, 12:43 PM   #20
86TOYO2k17
Drives: 2017 toyota 86
Longer front runners 4-1 or 4-2 increase power at the top end
Shorter front runners 4-1 or 4-2 increase power at midrange
Longer 2-1 runners increase mid range,
Shorter 2-1 runners increase top end.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
gpvecchi (03-21-2022), Jdmjunkie (03-21-2022)
Old 03-21-2022, 04:47 PM   #21
gpvecchi
gpvecchi's Avatar
I wouldn't say that Revolution headers aren't great: all the dynos I found of Revolution headers, Revolution/Gruppe M intake, 70 mm throttle body and Revolution/Revotec remap are around 220 HP and 24 Nm torque (japanese premium fuel)...
Old 03-22-2022, 10:26 PM   #22
FSFRS
Drives: '13 FR-S Firestorm
I recently took off my stock header (didn't have shields either) and was surprised how similar it looked to the 1st image.
FSFRS is offline   Reply With Quote
Old 03-23-2022, 03:50 AM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
I wouldn't consider similarity to stock as any kind of pro, rather opposite, as stock header for several prioritized reasons, like emissions, mass production cost, clearance, might be more compromised then aftermarket parts with performance as main goal.
Characteristic subaru-ish UEL was not put there on many subbies for specific sound. Design was chosen such to reduce material used and cut costs, with worse performance compensated with more boost. I'm sure, that there are many compromises with stock twins header aswell, such as below optimal runner lengths, too wide merge angles and such. Different priorities.
The Following User Says Thank You to churchx For This Useful Post:
grumpysnapper (03-24-2022)
Old 03-23-2022, 04:44 AM   #24
tomm.brz
Drives: brz 2017 hksv2
actually stock headers perform quite good if decatted, very similar to hks el
>17 stock headers are better because they are real EL and a bit bigger.. with good fuel you get basically the same performance as hks El, they also fill the dip quite good
The Following User Says Thank You to tomm.brz For This Useful Post:
p1l0t (03-28-2022)
Old 03-23-2022, 07:05 AM   #25
Brz-123
That's news to me. Did they change exhaust headers/ manifold in 2017+ MY? I thought they changed the intake manifold from black plastic to red aluminium which added 5 HP but did nothing on the exhaust side.
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 03-23-2022, 07:20 AM   #26
tomm.brz
the red aluminum manifold doesn't really add anything, also it heat-soaks and transfers heat more easily to the charge compared to the plastic one
The exh header changed a bit and that's also why has more HP
We in Europe didn't get it
/OT
Brz-123 (03-23-2022)
Old 03-23-2022, 08:22 AM   #27
Brz-123
/OT
Thank you for that. Now I know why I don't know as it didn't happen in Europe. The 2022 / new GR86 header will be even better as per the videos from Stratfield and their dyno runs.
Old 03-23-2022, 11:09 AM   #28
KillerBMotorsport
I didn't say any were bad, just based on appearance one has a better design. I've designed a LOT of headers over the years, many for Subaru engines, and tested/compared Subaru headers, more than I can count. Appearance is a horrible metric to judge a header by though. Testing rules all, regardless of what anyone might think.
4-2-1 is not ideal from a performance optimization standpoint. A 4-1 will always perform better, unless the design envelope causes a poor layout, which is almost always why a 4-2-1 version is used. A header is further down the road on our project list, but we will test everything first to know where the bar sits performance wise. I'm more concerned about price point where there must be a cat included TBH.
Best manifolds (headers) to OFT - OpenFlashTablet petermmdk Engine, Exhaust, Transmission 14 02-09-2021 02:01 PM
RHD/LHD Manifolds secret.squirrel Engine, Exhaust, Transmission 4 03-11-2016 03:31 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
EGT or O2 logging with UEL exhaust manifolds? burdickjp Engine, Exhaust, Transmission 0 01-23-2015 03:46 PM
Performance manifolds Nitro_FRS Engine, Exhaust, Transmission 20 10-17-2013 12:42 PM
