Old 03-03-2022, 09:52 PM   #15
Garvin29
Drives: Subaru BRZ limited 2015
I see, it seems that the most reliable and least complicated thing will be to buy the CP 10.5:1 pistons and not complicate my life, thanks anyway, I know that many easily reach that goal with E85. and for the guys above it will not be a stock block the question is for me to decide which piston was more suitable for my goal, I already have a lot of accessories to help keep everything good, oil cooler, a configuration of oil cans that have lowered the pressure in the crankcase, oil deflectors, oil pickup, ect. The last thing I need is to build the engine.
Garvin29 is offline   Reply With Quote
Old 03-03-2022, 10:33 PM   #16
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
You could get an IAG short block instead of building it. They also machine it to help the oiling issues.
I got a smooth brain.
Poogchomp is offline   Reply With Quote
The Following User Says Thank You to Poogchomp For This Useful Post:
p1l0t (03-04-2022)
Old 03-04-2022, 01:24 AM   #17
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I think the FA20F in the WRX is 10.6:1. People seem to be knock limited on the stock block sub 325whp with pump gas. I don't know if aftermarket rods and pistons can take a beating surviving 400whp with knock or worse. Direct injection helps, but lower compression ratio is a good idea. I don't know how much direct injection improves knock resistance. Older EVOs and STIs were maxing out pump gas around 400-425whp and that was with a 8-9:1 compression ratio.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
p1l0t (03-04-2022)
Old 03-04-2022, 06:08 PM   #18
86TOYO2k17
Drives: 2017 toyota 86
Doesn’t seem like stock block lasts long over the 3-350whp range regardless of octane.
But is there even any documentation of anyone even hitting 400whp on pump regardless of built block or lower compression or not?
Old 03-04-2022, 06:12 PM   #19
p1l0t
p1l0t's Avatar
The other thread claimed 693hp was the record on the stock block (probably not pump gas though). I'm sure that isn't a daily driver, lol.
Old 03-04-2022, 06:38 PM   #20
86TOYO2k17
Yeah not on pump gas. And making 693whp once on a dyno to never go over 10% throttle again and never actually use the power isn’t really the same thing.
300-320whp w/ sc or 330-350whp w/ turbo even on Ethanol seems the top end of reliable on stock block if you’re actually going to use the power.
But reliability aside, I don’t think I’ve seen anyone hit 400whp+ on pump gas regardless of compression.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
p1l0t (03-04-2022)
Old 03-05-2022, 12:32 PM   #21
JOSEC
Drives: 2014 Subaru BRZ WRB
I got it. Built Block. Head work. +1 Intake and Exhaust.
GTX2867R Gen 2. 18.5 Pounds. 420WHP On a Dynojet 93OCT.
JOSEC is offline   Reply With Quote
Old 03-05-2022, 01:59 PM   #22
86TOYO2k17
Have a dyno? Build thread?
Old 03-05-2022, 05:22 PM   #23
JOSEC
No build thread. But here it is.
The Following 2 Users Say Thank You to JOSEC For This Useful Post:
86TOYO2k17 (03-05-2022), p1l0t (03-06-2022)
Old 03-05-2022, 10:43 PM   #24
86TOYO2k17
Attachment 210102
Nice power.
What was the change from red to blue?
Old 03-06-2022, 04:27 AM   #25
tomm.brz
Drives: brz 2017 hksv2
i haven t understood if that is with stock compression or lowered? i guess lowered?
Old 03-06-2022, 07:03 AM   #26
JOSEC
Nice power.
2 different Maps.
Map 1, Red Line is gate pressure at 17 PSI. 380WHP I think somewhere around 320 TQ.
Blue is Map 2, 18.5PSI More timing. 420 WHP. 347 TQ.
Both gets on boost 3-3.5K. Lots of response, very linear power.
It’s my track car, so there was more power with more aggressive timing. But wanted to keep it more conservative.
86TOYO2k17 (03-06-2022), p1l0t (03-06-2022)
Old 03-06-2022, 07:03 AM   #27
JOSEC
Lowered compression. 10.5:1
86TOYO2k17 (03-06-2022), tomm.brz (03-06-2022)
Old 03-06-2022, 10:51 AM   #28
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
My understanding is you start eating transmissions and axels at those levels. So you change one thing in a huge way, you need to reenforce everything else ancillary to it. I’m just puttering around at 252whp, but also research for the “one day” thoughts.
The gen 2 transmission is supposedly stronger, but I’m not sure if it is a direct bolt-up.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
BRZ engine compression 13.5:1 or 12.5:1? mangler BRZ Second-Gen (2022+) — General Topics 2 12-05-2021 05:16 PM
Lowering compression Boris_Petrov Forced Induction 3 01-19-2019 05:19 AM
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
