| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#15 | |
Drives: frs
https://www.amazon.com/Rust-Oleum-Au.../dp/B006ZLQELW It doesnt smell anything nor have color on it. Never tasted thought but will leave your paint clean slate |
#16 |
Drives: 2013 FR-S Series 10
It was a aerosol can product i saw, didn't see the liquid one.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#17 |
Drives: 2020 Toyota 86 GT 6M
carpro eraser. it's what detailers who work with cquartz use to prep the car surfaces prior to ceramic coating
#18 |
Drives: 17 Asphalt 86
You need to get pretty aggressive to kill most modern sealants with just chemicals. And usually it's repeated steps.
I like to wash, then decontaminate with a good iron/fallout remover then clay. You might be able to just use the iron remover, but it won't get all the junk off the paint. I use whatever good car soap I have laying around and add some meguiars APC to boost cleaning power. Carpro iron-X smells horrible but it works great from my experience. Mother's clay 2.0 is a good synthetic clay mitt that's readily available. I used both of these doing my last decontamination wash. Optimum ferrex and optimum clay towel is efficient combo. Ferrex is both a chemical stripper and a clay lubricant. You can do two steps at once which saves you time. I am about to order these two for the next round. Carpro eraser is a good paint prep. A paint prep won't strip sealants, it isn't designed to do that. Think of it as a oil remover/degreaser that leaves no residue; to ensure best adhesion. Eraser probably isn't nesssary for applying regular sealants. I bought a bottle when I did a ceramic coating a couple years ago, and use it now and then during prep because I already have it. Last edited by RToyo86; 11-01-2021 at 10:59 PM. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | spcmafia (11-02-2021) |
#19 |
Drives: 2022' GR86 Premium 6MT
What sealant is currently on your vehicle and how strong is it currently?
If you're using a Foam Cannon, try a few ounces of Meguiars APC alongside your soap. Typically if I'm prepping a surface, the vehicle is getting polished. That's the best way to guarantee the surface is good to go. I wouldn't put dawn dish soap on your paint period lol
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#20 |
Eraser isn't going to remove a coating or sealant. Eraser is a polish and oil remover, it's pretty much fancy isopropyl alcohol.
#21 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
| DIY ECU removal | Hawaiian | DIY (Do-It-Yourself) Guides | 21 | 02-05-2023 01:19 AM |
| Bug removal | Jarrid'sBRZ | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 06-23-2017 04:12 PM |
| ABS removal | Zer0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-11-2016 05:39 PM |
| ABS Removal | Nigelr32 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 08-18-2015 06:46 PM |
| bug removal | TazMotorsports | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 30 | 03-31-2015 10:30 AM |
