Old 09-10-2016, 03:34 PM   #1
Zer0
Drives: 2015 frs
ABS removal
Im looking to see if the car cluster will still get a speed signal if I remove the ABS computer and block. No safety concerns I already have manual brakes and run with the ABS fuse pulled.Just need to know what electronic side affects I might have. If none I want to remove this from the harness completely. My car is tore down for a swap otherwise I would unplug and test it for myself.
Zer0 is offline   Reply With Quote
Old 09-10-2016, 10:59 PM   #2
Zer0
Drives: 2015 frs
This is what the ABS body looks like taken apart.
Old 09-10-2016, 11:05 PM   #3
Zer0
Drives: 2015 frs
It appears to be solenoid valves in the block. Coils to activate the valves as needed in the electronic section of the unit, and a electric motor on the opposite side of the block from the valve assembly. which could be a internal pump I would think. I may try to keep just the electronic section and remove the valve body. I guess I'm a pioneer as I can't find much info on this subject. Lol
Old 09-10-2016, 11:46 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
We run just the electrical half tucked away and plugged in so we still get wheel speed through the can bus into our motec ecu
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 09-11-2016, 07:22 AM   #5
Zer0
Drives: 2015 frs
Thanks for the information. That was the plan if I can't get the information to remove it all and keep all signals I need.
Did you remove the coils from the electrical side?
Old 09-11-2016, 09:47 AM   #6
spitfire481
Drives: 2JZ FRS
We run just the black part in your second picture. Just made a quick plastic cover to seal it off. Without it plugged in we can't get wheel speed on can bus so the speed sensors go through that module without a doubt
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Zer0 (09-11-2016)
Old 09-11-2016, 05:39 PM   #7
Zer0
Drives: 2015 frs
@spitfire 481 Thank you for the information. It makes everybody's build go smoother when we can collaborate with people who have been there done that, and are willing to share there knowledge.
The Following User Says Thank You to Zer0 For This Useful Post:
spitfire481 (09-11-2016)
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 01:19 AM
oil pan removal SirSpectre Forced Induction 13 10-30-2017 12:05 PM
ABS Removal Nigelr32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-18-2015 06:46 PM
bug removal TazMotorsports Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 30 03-31-2015 10:30 AM
Dent removal? ZOMFGAARON Southern California 5 04-07-2014 10:19 AM
