Old 09-07-2021, 11:23 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by 86league View Post
Aftermarket tune? The stock tune has something like this as well?
I thought I remembered reading reports of the ECU cutting power with high temps, but a quick search didn't find what I remembered from years back.
Custom tune. Seems I've read that the factory tune might cut power around 300F? Not sure on that.
Old 09-08-2021, 01:58 AM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by ZDan View Post
Forgot to update this! The tune was cutting back on throttle at 275F.
Well, that's an interesting data point, given the recent discussions on whether an oil cooler is needed.
Might as well explain why your oil never gets too hot
It's also interesting that your tune implements the "oh the engine is too hot" by faking the accelerator pedal position, rather than something else, such as altering the lookup in the drive-by-wire table.
If the accelerator pedal is pressed all the way, one could argue any data logging must show 100% accelerator pedal position.
Which OBD PID / CAN ID does your data logging system use for the "accelerator pedal position"?
timurrrr is offline   Reply With Quote
Old 09-08-2021, 07:01 AM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
I would consider 275F to be an absolute upper limit for 0w20, but low for good 5w30.
It seems like I've read that factory setting for calling things off is at 300F, for sure before the tune I never ran into any cutoff.
Yeah, that data is sort of misnamed, should be "throttle commanded by ECU" and not "pedal position".
I don't know, but confirmed that it is *not* actual pedal position but rather what the ECU is dictating for throttle.
Old 09-08-2021, 03:04 PM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Use CAN ID 320 (0x140 hex), first byte, divide by 2.55 to get 0...100 range.
Old 09-08-2021, 03:33 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'm not much of a data jockey... I use the ECUtek software to view data, that's it. Again, it's been confirmed by the tuner that tune applies a multiplier to applied pedal at high oil temps and high rpm, so it's known to be controlled by the tune at that point and not actual pedal position.
Old 09-08-2021, 11:16 PM   #20
renfield90
The Stig's German cousin
I wasn't aware there was a table for this - any idea what it's called?
Old 09-16-2021, 02:43 PM   #21
Shoebox
Shoebox's Avatar
Drives: 2013 Subaru BRZ
Like I said!
Oil cooler setup is, nonexistent...
I'm not worried about 5w30 at 275F. Oil pressure should be about what it is for 0w20 at 250F. Or 5w30 at 250F with an oil cooler, at least according to this data:
https://www.ft86club.com/forums/showthread.php?t=91820
Yeah my oil almost never gets over 230F, with an oil cooler. It regularly got over 275F before an oil cooler. It’s cool if you want to drive around with limited power. And oil pressure at idle is irrelevant…..
Shoebox is offline   Reply With Quote
Old 09-16-2021, 04:07 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Who's talking about oil pressure at idle?
FWIW I had same max speeds at COMSCC Palmer event 1 this year vs. a car very similar to mine with slightly more peak power and slightly less midrange torque (he has 4-1 EL catless, I have 4-2-1 catless) and he has an oil cooler, so...
By "limited power" do you mean the factory tune cuts timing advance at some oil temperature? Dunno if my aftermarket tune does or not but in any case our max speeds were similar to when we were running full factory exhausts and tunes anyway...
Old 09-16-2021, 04:26 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Watkins Glen event on Mon/Tue went GREAT (except for a couple of partially stripped wheel studs )!
I was able to run extended sessions, no problemo
Did a 2:14.870 on day 1 and 2:15.335 on day 2 (headwinds, everybody was slower) and TT'd 2:15.688 which was enough to take the win in T50 by 2+ seconds vs. Miata I've been going back and forth with this year
https://www.comscc.org/events/result...?id=2021-09-14
Having the oil temp trigger reset to 285F resulted in never running into the tune cutting back on commanded throttle. Oil temp on the factory gauge remained at the same normal level of just over 270F indicated.
Sweeet...
Forgot to update this! The tune was cutting back on throttle at 275F. Had the trigger bumped up 10 degrees to 285. See how it goes at Watkins Glen in a week!
Old 09-16-2021, 05:12 PM   #24
Sweeet...
Time for some proper studs and open ended lugs! Which I suppose is annoying given your road salt and stuff...
Old 09-16-2021, 05:23 PM   #25
ZDan
ZDan's Avatar
Drives: '23 BRZ
I have the shorty ARP studs so I can run closed-ended lug nuts on the street.
I got some purty rainbow-colored Muteki lug nuts for track for this year for max disco. Before going to the Glen I noticed one of them hanging up a smidge while changing wheels/tires for the trip. Ran down one of my street lugs on that stud by hand, no problemo, so I "cleaned up" the Muteki lug nut with a tap and then it installed fine by hand. *At that moment I should have removed all the Muteki lug nuts*.
At the track while removing the left front wheel on day 1, one of the Muteki lugs was dragging, and then halfway through removing it, it totally siezed up. Took a big-daddy impact to remove it. Cleaned off the outer half of the ARP stud but the inner threads were fine and I was able to get a few good turns on it. Took max torque with my street lug nuts no prob.
Day 2, exact same thing happened on the right rear.
TL/DR: Muteki lug nuts are *shite*. WAY worse than off-the-shelf "tuner" lug nuts from Pep Boys (the "street" lug nuts I've been using street and track for a few years now).
Old 09-17-2021, 11:25 AM   #26
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Sweeet...
So in your situation, what do you think would be the better fix out of these two examples?
1) Increase the thermal safety limit so that the ECU can't limit the power output of the engine when the oil reaches the original temperature setpoint,
or
2) Install an oil cooler so that the oil temperature doesn't reach the original thermal limit in the first place.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 09-17-2021, 12:09 PM   #27
gcranston
Drives: 2015 Subaru BRZ Limited DGM
or
But that's not what actually happened. The original temperature setpoint was _lowered_ by the custom tune on the ECU. So as I see it, the question should be "which of the following is the most effective for engine longevity":
  1. No action - factory oil temperature setpoint and 5W30
  2. custom tune to lower temperature setpoint
  3. oil cooler to reduce oil temperature well below setpoint
gcranston is offline   Reply With Quote
Old 09-17-2021, 12:16 PM   #28
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I'll admit I've glossed over this thread... But why Not buy an oil cooler? regardless of the oil's thermal capacity itself it literally is cheap insurance for a motor seeing track use.
Kelse92 is offline   Reply With Quote
Clutch pedal - "squishy/squeeky" sound? tanner Engine, Exhaust, Transmission 16 07-27-2017 03:59 PM
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 04:59 PM
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 08:44 PM
Just changed pads and fluid; brake pedal has more "dead space" ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-13-2015 03:56 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 04:02 AM
