Old 09-30-2020, 11:11 PM   #15
86league
Drives: '13 BRZ Limited
I did some research before just going with Centric last year. According to posts I found, Timken sources some of their stuff from other manufactures as well, so you may well buy a centric and a timken and get hubs from the same production line.
Didn't think paying the extra for the timken was worth it. Living in Tx I didn't have a rust problem and the front hubs are pretty easy given that. Figured I could re-do them if the centrics didn't last.
86league is offline   Reply With Quote
Old 10-07-2020, 09:18 PM   #16
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Update...completed the job using Centric hubs, and it went fine. Getting the old hubs out was, as some have said, not exactly a walk in the park especially considering the five CNY winters they've been through. Didn't have a Hub Buster or other special tool, but there was enough room available to get some swing with a big ol' hammer from the back side to get'em knocked out. New hubs, rotors, and pads installed and feeling great.
Bad news... Hankook Ventus tires showed an insane amount of treadwear and scalloping on the inner surfaces...only got about 15k miles out of them. No track stuff..just spirited (but responsible, meaning some hard cornering but no drifting or burnouts) daily driving. Typical? Alignment advised after new hub installation?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
bhmax (10-27-2020)
Old 10-09-2020, 12:16 AM   #17
jflogerzi
jflogerzi's Avatar
I would just do it anyways and throw in some crash bolts to get some negitive camber
2013 Series 10 FRS #553
Old 10-14-2020, 02:42 AM   #18
norcalpb
norcalpb's Avatar
The hubs do not come with studs or mounting bolts. Don't forget to remove the wheel speed sensor before trying to pull out the hub or you will damage it. Given the mileage of your car it is not going to come out easy, the hub is a snug fit in the knuckle. You may need to persuade it with a mallet. The OEM hub bolts are held in with blue loctite, I'd recommend using it on assembly. I suggest using a 6 point socket, you will need a 3" extension to get it in there.
It might not have been the case in the past I guess but my new OEM hubs came with pre-mounted studs.
The Following User Says Thank You to norcalpb For This Useful Post:
NoHaveMSG (10-14-2020)
Old 10-16-2020, 09:03 PM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
They pretty much all do. Pounding out the old to pound in the arp studs is part of the fun!
SCCA T4 - FRS
handling after new wheel and bearings JackRabbit Issues | Warranty | Recalls / TSB 15 01-24-2020 05:53 PM
BRZ wheel bearings same as 86? JackRabbit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-06-2020 02:52 PM
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 02:58 AM
Wheel bearings gone bad rustymuffler Issues | Warranty | Recalls / TSB 25 05-02-2019 12:21 PM
Performance wheel bearings MassTroy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2018 01:03 PM
