Tracking / Autocross / HPDE / Drifting What these cars were built for! |
10-02-2020, 11:04 AM | #15 |
Drives: 2014 Subaru BRZ Limited MTblue
Same
Glad to see this thread. Before a third track session of the day (in August 2020) had ABS & Traction control warning lights come on. The Torque app reported no error codes. Checked fuses, but didn't leave them out. Missed the session, trying to figure it out. Restarting the car was no use. Eventually, the lights went off on their own. And haven't returned after many following track days.
2014 stock brakes CSG Tein Flex A's tight suspension -3 7/8° front camber, -3° rear, Front 1/16" total toe out, rear 1/16" total toe in |
10-19-2020, 01:06 PM | #16 |
Drives: 06 Exige, 17 BRZ PP
I had something similar happen at VIR this past weekend.
After hitting the gators coming out of oak tree the ABS light went on. No VSC warning light The next lap, braking zone into T1, the right rear and right front locked up without much pedal pressure. Releasing the pedal did not immediately unlock the wheels. Flat spotted new RS-4s ABS Light went off after turning off the car, and didnt have the problem again. |
10-19-2020, 05:21 PM | #17 | |
Drives: '23 BRZ
Damn... So basically even if just the ABS light comes on, we should all be taking it SUPER EASY into the next braking zone! Damn haunted ABS/VSC....
I just pull the 40A fuse for tracking now. No matter what the computer *thinks*, it can't apply pressure to the brakes! On the street, I haven't had any lights at all, and no weird braking behavior. Quote:
10-19-2020, 06:19 PM | #18 |
Drives: Nevermorange FRS
I wonder if there’s a correlation on brake fluid replacement intervals or if it’s solely an electronic issue.
edit: This only comes to mind because I know in some cars, brake fluid neglect causes premature failure or issues with ABS blocks.
SCCA T4 - FRS
10-19-2020, 07:47 PM | #19 |
Drives: '23 BRZ
It's not the brake fluid... For one thing mine gets fully flushed once a year, and for another in my case there is a yaw sensor error involved, which I don't believe could be related to "bad" or old brake fluid.
10-21-2020, 11:21 AM | #20 | |
Drives: FR-S Turbo
Yes - I nuked my set of AR1s because of a massive front lock up as the systems we're talking about failed (and turned off) in the middle of a heavy braking zone. |
10-21-2020, 11:24 AM | #21 | |
Drives: FR-S Turbo
Curious what you found out because in my situation it was pretty cut and dried. |
11-03-2020, 10:27 AM | #22 |
Drives: Ultramarine FR-S
Did you do a 2:14 on the continentals or the a7s?
11-03-2020, 02:45 PM | #23 |
Drives: '23 BRZ
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
12-11-2020, 02:50 PM | #24 |
Site Moderator
Drives: Stuff
Just had the same thing happen on my FRS in the braking zone for T7 (hairpin) at Sebring. Lights out after restarting the car. I dont think I have my good code reader here unfortunately. DESTROYED 2 basically new GY Supercar 3R tires too
On the plus side I'm ~3 seconds a lap faster with CSG spec SRCs than the Eibach R2s.. @CSG Mike Going to be a total ***** next time out... I still have tomorrow day, tomorrow night and sunday day track time this weekend so pulling the f'ing ABS fuse if I have to. On a sidenote the car WAS just aligned. THe steering wheel is offcenter slightly so I'm wondering if it needs to be centered through the toyota software (techstream?). I checked all suspension bolts (always do after alignments) this morning and all were snug. I will check them again.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-11-2020, 03:35 PM | #25 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
12-11-2020, 04:19 PM | #26 | ||
Drives: '23 BRZ
Front lockups I presume? Symmetrically or did one side lock up sooner/harder? That was how it worked for me... Fortunately I was on Conti ECS at the time and they're hard enough they didn't get badly flatspotted. Quote:
I couldn't track the car safely until I pulled the fuse. Next event at Palmer, first time out I forgot to pull fuse, so took it easy for a few laps then came in and pulled it. Unfortunately it was cool to cold ambient temps at Palmer and I had a couple of normal, controllable front lockups but flatspotted the bejeezus out of one of my A7s, had to TT on the Contis :'( I felt like my CSG spec C2 front pads worked a lot better cold than my WinMax W5 rears, hence too much initial front bias => early front lockups. Wasn't a problem running sans ABS at Watkins Glen. |
12-11-2020, 04:42 PM | #27 | |
Site Moderator
Drives: Stuff
Its throwing a steering angle circuit code every time it happens (turns out i did have my reader). I threw that clockspring in it from a wrecked car so I'm thinking its just damaged and getting worse... or that combined with the off center alignment is just enough to piss off the vsc system. As for the lockup, front left, then front right, then both with the left leading a little. Breath on the brakes after they do it and they insta lock so i gave up on the tires lives to save the car instead.
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | CSG Mike (12-13-2020) |
12-11-2020, 06:32 PM | #28 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (12-13-2020) |
Similar Threads | ||||
door ajar warning light | Cobaltbloo | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 01-12-2020 06:04 PM |
Warning Light? | albeezy | Issues | Warranty | Recalls / TSB | 49 | 12-22-2016 08:01 PM |
my warning egine light is on | vinpan | Issues | Warranty | Recalls / TSB | 10 | 05-07-2013 11:44 PM |
TPMS warning light | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-30-2012 08:24 PM |
Warning light came on, what could it be? | whtchocla7e | Issues | Warranty | Recalls / TSB | 13 | 10-21-2012 04:20 PM |
