Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 09-14-2020, 07:41 PM   #15
Joon525
Joon525's Avatar
Drives: 2016 BRZ
PMP is reputable and have supplied a bunch of engines for people I know in our state.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
gravitylover (09-15-2020)
Old 09-14-2020, 08:09 PM   #16
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by 86TOYO2k17 View Post
https://www.ebay.com/itm/2013-2016-S...-/274333242924
Get a refurb, 3200$ shipped. Probably safest bet for it not having issues compared to buying used at similar price point.
That's a short block. You can get a Stage 1 IAG for about the same price with beefed up internals and better oiling capabilities. The labor when you just get a short block is pretty high. A long block would mean a complete engine. If your engine issue included bad bearings or anything that caused metal shavings to get into the oil then everything that the oil touched needs to be either replaced or refurbished. Plan on around 8-10K if there was metal in the oil.
Short block and you're still dealing with the timing cover issue and the potential of the technician not knowing the correct procedure then you're back to square 1. This is an extremely frustrating situation I just went through it. If your budget is 4K a new motor will not happen.
You can get a short block from other outlets for 2K. If you decide to go that route
The Following User Says Thank You to TommyW For This Useful Post:
Old 09-14-2020, 08:25 PM   #17
86TOYO2k17
Drives: 2017 toyota 86
Pretty sure it’s a long block.
Old 09-14-2020, 08:39 PM   #18
TommyW
TommyW's Avatar
That pic is a short block
Old 09-14-2020, 08:40 PM   #19
86TOYO2k17
The pic of the heads and cams and longblock? Or just pic 1 of 10?
Old 09-14-2020, 10:23 PM   #20
TommyW
TommyW's Avatar
Longblock would be plug n play. If you could find one I imagine it would be around 7-8K but I'm guessing on that
Old 09-14-2020, 10:28 PM   #21
WildCard600
WildCard600's Avatar
Drives: 2020 86
I think your definition of long block and short block are different than.... well, everyone else.
WildCard600 is offline   Reply With Quote
The Following 3 Users Say Thank You to WildCard600 For This Useful Post:
86TOYO2k17 (09-14-2020), NoHaveMSG (09-14-2020), ScoobsMcGee (09-14-2020)
Old 09-14-2020, 10:33 PM   #22
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
A short block is just the block, crank, rods, and pistons.
A long block is all of that plus heads, cams, and valvetrain.
I'm pretty sure you're confusing a long block with a complete engine that has all of the other stuff on it (pumps, hoses, oil pan, intake manifold, throttle body, etc).
The Following 5 Users Say Thank You to ScoobsMcGee For This Useful Post:
86TOYO2k17 (09-14-2020), brandonblt2 (10-16-2020), gravitylover (09-15-2020), NoHaveMSG (09-14-2020), WildCard600 (09-14-2020)
Old 09-14-2020, 10:43 PM   #23
86TOYO2k17
I think you are mistaking longblock with complete engine assembly.
New Short blocks can be picked up from Subaru for 2k.
Long block is a short block + heads (valves, springs, cams Etc.)
It still needs all the sensors, solenoids, engine harness, manifolds, oil pan, and a few other minor things sometimes timing cover.
Complete engine assembly is drop in and go.
Long block is transfer over some external things from current engine and good to go
Look at ALL 10 of the pictures. Clearly shows a head with valves, springs, cams etc.
Complete or near complete used engine assemblies can be had for roughly 3k, this is a refurbished long block with a core fee of 750$, so close to 4k$ but 3200$ once core is returned. Not sure why they would clearly show a short block + heads (ie long block) if it was only a short block and didn’t include the heads...
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
ScoobsMcGee (09-15-2020)
Old 09-14-2020, 11:11 PM   #24
TommyW
TommyW's Avatar
Thanks. Youre right. Heads and all the top end goodies.
Old 09-15-2020, 09:10 AM   #25
gravitylover
Short block - Lower end
Long block - bottom and top end but no peripherals. Still needs intake, hoses, plugs, wires, harness, etc
Complete - plug and play. Best to change wear parts before it goes in.
Thank you.
I like the idea of getting this used engine that has less than half the mileage mine does. I'll swap in new wear parts, maybe even a new clutch since mine has 47k on it. I think I'm also going to buy an engine stand and keep my old one and rebuild it slowly. I've always wanted to learn about this stuff and this seems like the perfect opportunity. I (sort of) have the space so I'm going to build a dry enclosure in the driveway by my outside workbench area.
Old 09-15-2020, 01:05 PM   #26
TommyW
TommyW's Avatar
Originally Posted by gravitylover View Post
Thank you.
If you have the capabilities to do the work yourself then you're in a great position to make this happen for a reasonable amount. Good luck! Youtube is your friend. There is a ton of info on rebuilding this motor.
Old 09-15-2020, 05:23 PM   #27
gravitylover
I'll find out if I do If I spend enough on tools and take my time I bet I can do it pretty well.
Old 09-15-2020, 06:49 PM   #28
TommyW
TommyW's Avatar
That could be your new profession!
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring Engine, Exhaust, Bolt-Ons 10 11-26-2014 12:38 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 09:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
