#15 | |
#16 |
Drives: 2013 FR-S 10 series [755]
I am having that problem as well.. only when AC on tho.
I remember OFT can fix this problem? correct me if i am wrong. |
#17 | |
OFT can probably turn off the dry cycle when on heat and defrost but it will have no impact when the AC is on since it is just the sudden draw of the compressor that is causing the drop.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | FRSBRZGT86FAN (05-04-2016), mdm (05-04-2016) |
#18 | |
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
#19 | |
Mine has had the idle drop twice when coming in off a long run on the highway. Considering I do a long run on the highway 5 days a week and have for the last 1 1/2 years I am not worried about it.
#20 | |
Drive From Home
Drives: BRZ STI Performance
However my 2014 manual BRZ made in Summer 2013 has never done this even with the A/C on. |
#21 | |
#22 | ||
There was actually an idle fix ecu flash for 2013s and of course applied in production for future models that's why it's not as crazy as before.
#23 |
Drives: frs
I got the reflash at dealer and still have the dip. I gave up and add it to the quirks list. Considering the oft tought.
#24 |
Drives: 2013 Pearl White 6MT
Mine does it, everyone's does it, but shouldn't. I'm gona see if toyota will re-flash mine when I take it in for next service
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#25 | |
yep the 2015 auto need the auto controll unit reflash oft tunes just bump the idle 50 or 100 rpm above stock. better fix is to adjust the idle compensation tables |
| The Following User Says Thank You to steve99 For This Useful Post: | Tcoat (05-05-2016) |
#26 |
Drives: 2016 Cosworth 2.2 BRZ
I have a 2016 Limited manual with a Cosworth 1.0 EcuTek tune. Mine does it too when the A/C compressor is on. If I come off the highway and shift into neutral, the idle will drop to about 500rpm and shudder a little. It doesn't do it very much when standing still and doesn't do it all if the A/C is not running.
So I don't believe it's just a tune issue although it's possible that Cosworth did not compensate for it. Maybe it can still be tuned out. I wonder if @Matt@Cosworth has noticed this on any other Cosworth vehicles. Is the problem in ECU tuning or is it a mechanical issue? Maybe the little 2.0 is just not strong enough to quickly compensate for the A/C compressor cycling. |
| The Following User Says Thank You to sly For This Useful Post: | Tcoat (05-05-2016) |
#27 | |
All 3 of my Lancers would struggle like hell when the compressor kicked in since the small displacement takes a second to catch the dip. These engines make all their power through revs so when a load is suddenly placed on them at low RPM they need to catch up.
#28 | |
Drives: blue - Cosworth SC stage 3.0
on the stage 1 tune all the stock idle speed control was carried across so its the same as the standard car in this respect and I've found it will improve after flashing once its done about 200 miles as it applies the learned settings |
| iPod issue? | Mr.Jay | Electronics | Audio | NAV | Infotainment | 12 | 02-10-2013 03:41 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Question about Plasti-Dipping. | Asterisked Accolade | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 08-12-2012 01:38 AM |
| The weight issue | mickey177 | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 07-27-2012 09:47 AM |
| Opticoat issue | dav0777x | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-24-2012 06:42 PM |
