Old 06-19-2020, 09:38 AM   #15
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Originally Posted by solidsnake11 View Post
The ring behind the flywheel with teeth on it. It has a dowel that has to be lined up for correct crank position.
I think the question is did he remove the flywheel to resurface during the clutch replacement and did he mess with the sensor plate. If he did I bet you are right about the crank sensor plate being misaligned...which means doing the whole job over again.
skylinekin is offline   Reply With Quote
The Following User Says Thank You to skylinekin For This Useful Post:
solidsnake11 (06-19-2020)
Old 06-19-2020, 10:00 AM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s indexed with a pin in the crank. I don’t think you can misalign it without the flywheel being crooked.
Old 06-19-2020, 10:01 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post:
solidsnake11 (06-20-2020)
Old 06-19-2020, 10:29 AM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Crank but no start after clutch rep.
Double post
Old 06-19-2020, 12:24 PM   #19
RWD fun
That thin metal plate? I put it edge-side towards the motor. Do it also have a specific position it needs to be in?
RWD fun is offline   Reply With Quote
The Following User Says Thank You to RWD fun For This Useful Post:
Old 06-19-2020, 01:18 PM   #20
solidsnake11
Drives: brz
Set tdc on front pulley then the sensor should align with the tooth that says tdc in picture.
Small hole is the dowel alignment hole.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
RWD fun (06-22-2020)
Old 06-19-2020, 01:24 PM   #21
RWD fun
Wow thanks, I wouldn't be surprised if this was my problem 🤦*♂️i have a 2013 i know reluctor is different
Old 06-19-2020, 01:34 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Edge-side does go toward engine. That is correct. There is a pin on the crank that it aligns on to index it.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (06-20-2020), RWD fun (06-22-2020), solidsnake11 (06-20-2020)
Old 06-19-2020, 01:35 PM   #23
solidsnake11
Drives: brz
Reluctor seems the same all except the tooth profile.
I have not had my hands on a 17+ only seen pictures.
Old 06-19-2020, 01:40 PM   #24
solidsnake11
Drives: brz
I was referring to checking alignment without pulling transmission. But yea if you take it apart this correct.
NoHaveMSG (06-19-2020)
Old 06-19-2020, 01:46 PM   #25
solidsnake11
Drives: brz
Its been done before by a member here.
Old 06-19-2020, 01:48 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it can happen it has happened I guess. Is that how that saying goes ?
It is a pretty shallow pin.
Old 06-20-2020, 12:34 PM   #27
RWD fun
It definitely happened. It was about 180 degrees off. We'll see after I get the trans on. lol.
The Following 2 Users Say Thank You to RWD fun For This Useful Post:
NoHaveMSG (06-20-2020), solidsnake11 (06-20-2020)
Old 06-20-2020, 01:33 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Shit happens, it's part of learning. Good on @solidsnake11 for giving you an idea on how to check it assembled. I wouldn't have thought of that.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (06-20-2020), solidsnake11 (06-20-2020)
No start No crank Anti-theft blinking 02maher Issues | Warranty | Recalls / TSB 37 05-18-2020 10:00 AM
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 07:30 PM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 06:44 AM
Car won't start, won't crank, no ecu communication redlined600 Issues | Warranty | Recalls / TSB 10 07-09-2016 01:55 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 07:22 AM
