#15 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
I think the question is did he remove the flywheel to resurface during the clutch replacement and did he mess with the sensor plate. If he did I bet you are right about the crank sensor plate being misaligned...which means doing the whole job over again.
| The Following User Says Thank You to skylinekin For This Useful Post: | solidsnake11 (06-19-2020) |
#16 | |
Drives: Crapcan
It’s indexed with a pin in the crank. I don’t think you can misalign it without the flywheel being crooked.
#17 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | solidsnake11 (06-20-2020) |
#18 |
Drives: Crapcan
Crank but no start after clutch rep.
Double post
#19 |
| The Following User Says Thank You to RWD fun For This Useful Post: | solidsnake11 (06-20-2020) |
#20 |
Drives: brz
Set tdc on front pulley then the sensor should align with the tooth that says tdc in picture. Small hole is the dowel alignment hole. |
| The Following User Says Thank You to solidsnake11 For This Useful Post: | RWD fun (06-22-2020) |
#21 |
Wow thanks, I wouldn't be surprised if this was my problem 🤦*♂️i have a 2013 i know reluctor is different
#22 |
Drives: Crapcan
Edge-side does go toward engine. That is correct. There is a pin on the crank that it aligns on to index it.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#23 |
Drives: brz
#26 |
Drives: Crapcan
If it can happen it has happened I guess. Is that how that saying goes ?
It is a pretty shallow pin.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | solidsnake11 (06-19-2020) |
#27 |
| The Following 2 Users Say Thank You to RWD fun For This Useful Post: | NoHaveMSG (06-20-2020), solidsnake11 (06-20-2020) |
#28 | |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | bcj (06-20-2020), solidsnake11 (06-20-2020) |
| No start No crank Anti-theft blinking | 02maher | Issues | Warranty | Recalls / TSB | 37 | 05-18-2020 09:00 AM |
| Car won't start - doesn't try to crank at all, but lights are working HELP | cdo221 | Issues | Warranty | Recalls / TSB | 28 | 06-06-2018 06:30 PM |
| Crank No start (Not battery issue) NEED HELP | cnxmist | Issues | Warranty | Recalls / TSB | 19 | 07-28-2017 05:44 AM |
| Car won't start, won't crank, no ecu communication | redlined600 | Issues | Warranty | Recalls / TSB | 10 | 07-09-2016 12:55 PM |
| No crank no start issue | *KID* | Issues | Warranty | Recalls / TSB | 3 | 09-29-2014 06:22 AM |
