Old 06-18-2020, 09:47 AM   #15
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by tomm.brz View Post
intake and exhaust cam will help
also flkc and knock corr, usually it gets reduced tova minimum of -0,7 instead of -1 as minimum correction
injection angle if available, try to put many things, i dont know how torque works
Torque logs thru OBD2 PIDs, so I'm limited to the PIDs that is available in the OBD2 protocol... To log FLKC and knock correction, I know it can be done with a Tactrix cable/OFT, but then I would have solved this problem in the first place as I could take a dump of the maps
Meanwhile I have added more OBD2 PIDs to another log below, I will soon bust out Techstream for additional logging parameters - thanks for having a look @tomm.brz and for entertaining me
https://datazap.me/u/compelica/normal-run?log=1&data=8
Compelica is offline   Reply With Quote
Old 06-18-2020, 06:13 PM   #16
steve99
Originally Posted by Compelica View Post
Sorry @tomm.brz I can get you the other info... I was under the assumption you needed only those columns that you stated earlier.
Is there anything else you require other than engine speed?
It looks like a stock tune from AFR
https://datazap.me/u/compelica/norma...8&zoom=307-337
that section shows AFR measured richest is 12.16 which is stock AFR scaling. Also the commanded AFR goes way rich to 10.5 AFR like stock tune. most tuners will lean commanded arf to about 11.8 stock has commanded afr down to 10.5 or so most tunes cars dont target that low
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Compelica (06-18-2020), tomm.brz (06-20-2020)
Old 06-20-2020, 01:19 AM   #17
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks @steve99 @tomm.brz for the insight.
The Following 2 Users Say Thank You to Compelica For This Useful Post:
steve99 (06-21-2020), tomm.brz (06-20-2020)
Looking for a good tune socal Blitz_86 Software Tuning 2 02-13-2019 11:20 AM
The just checking in everything is good thread go_a_way1 Issues | Warranty | Recalls / TSB 69 03-28-2016 10:04 PM
Good tune? Romiikr Software Tuning 7 12-20-2015 07:33 PM
Perin CAI W/O tune! good or not ? JdelFrs Software Tuning 8 03-05-2014 11:33 PM
Will this be a good decade for car enthusiasts? (huge list of cars) RaceR Other Vehicles & General Automotive Discussions 36 11-05-2012 05:53 PM
