#15 |
Drives: Ft86
what is your suggest while do repair it . it has failed 2 times . 2nd time overhaul complete engine with new short block / bank 1 cylinder head with OEM valves / recall valve springs / rockers / lashes / new cam / new timing gears . but unfortunately again within 2 days bank 1 rocker fallen ..
#16 | |
Drives: brz
Start at 5:00 for valve train. |
#17 | |
Drives: Crapcan
#18 |
Drives: brz
In the video you will notice that the exhaust has the shaft rockers. I would assume it happens more on the exhaust so maybe heat.
Their is also another video that shows how he redisned the rockers with deeper grooves when he was having problems. One theory. If the lash is loose the lifter could leave its seat and fill with oil and then when the cam hits the rocker it slams the lifter down creating oil pressure that pushes the rocker off the pivot |
| Rocker arm broke and broke my valve cover... | j0hnnykthx | Issues | Warranty | Recalls / TSB | 9 | 08-07-2020 08:12 AM |
| Key Fob broke down | RichardsFRS | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 12-29-2015 04:38 PM |
| Broke my OFT, now what?!? | edeekeos | Software Tuning | 18 | 01-21-2015 02:12 AM |
| This is why I'm broke | cdrazic93 | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 07-26-2014 03:15 PM |
| I think I broke the tie rod....... | jshum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 06-04-2014 12:41 AM |
