Old 08-07-2020, 12:17 PM   #15
DonAruna
Drives: Ft86
what is your suggest while do repair it . it has failed 2 times . 2nd time overhaul complete engine with new short block / bank 1 cylinder head with OEM valves / recall valve springs / rockers / lashes / new cam / new timing gears . but unfortunately again within 2 days bank 1 rocker fallen ..
DonAruna is offline   Reply With Quote
Old 08-07-2020, 12:30 PM   #16
solidsnake11
Drives: brz
Out of curiosity. In your experience, do you see a way to improperly assemble the head to where the car will run for a while and then have the rocker arm kick out? I don't see how it could be, just seems to be a sporadic failure in the early engines.
Having too much lash clearence would allow the rocker to move around. I know that papadakisracing.com had a problem with the toyota 2ar, about the same rocker setup except we have lash caps for shims that sit on the valve stem.
Start at 5:00 for valve train.
solidsnake11 is offline   Reply With Quote
Old 08-07-2020, 12:41 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
[/URL]
I had considered that, but i'd imagine they would have to be quite a ways out of spec. I had a couple that were on the lose side of spec, but not out of spec. My experience with bucket shim setups from motorcycles always seemed to be that they tightened as they wore in. So I let them be.
Old 08-07-2020, 01:46 PM   #18
solidsnake11
Drives: brz
In the video you will notice that the exhaust has the shaft rockers. I would assume it happens more on the exhaust so maybe heat.
Their is also another video that shows how he redisned the rockers with deeper grooves when he was having problems.
One theory.
If the lash is loose the lifter could leave its seat and fill with oil and then when the cam hits the rocker it slams the lifter down creating oil pressure that pushes the rocker off the pivot
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 08:12 AM
Key Fob broke down RichardsFRS Scion FR-S / Toyota 86 GT86 General Forum 10 12-29-2015 04:38 PM
Broke my OFT, now what?!? edeekeos Software Tuning 18 01-21-2015 02:12 AM
This is why I'm broke cdrazic93 Off-Topic Lounge [WARNING: NO POLITICS] 14 07-26-2014 03:15 PM
I think I broke the tie rod....... jshum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 06-04-2014 12:41 AM
