Drives: 2020 Subaru BRZ
broke it again, anyone evern seen this
Today while on a fairly spirited drive smoke came from under the hood and filled the cabin and behind the car looked like a Nascar blown engine. I started coasting to see if I could here anything. Oil pressure good no noise. Upon further investigation I was getting oil sprayed onto my header. The oil was coming from a hole in the valve cover. The valve cover looked like it threw a rod and put a hole in it. Obviously that didn't happen because the engine still runs fine. If anyone has seen this type of damage please chime in and let me know what the culprit was that caused this unusual damage.
I'll pull the engine this weekend to see what the problem is. I was unable to get any pics due to the location. Thanks for any input. |
Drives: brz
Probably a rocker arm got spit out. What year? Seems weird that it runs fine.
#3 | |
Drives: Crapcan
I suppose they are not immune to the issue just being a later model.
Rust bucket enthusiast
I'm not so sure. All of his threads are engine rebuild questions, including valve shims, trans swap inquiries, etc for a 2013 FRS. Maybe he has 2 cars. It seems like this 2013 has been through multiple engines
Drives: Crapcan
That would make a lot more sense. Would be nice if people who posted these help threads would put mods and history, never seems to be the case.
#6 | |
The car was not running "fine" 4 days ago... https://www.ft86club.com/forums/showthread.php?t=140692
Drives: Q5 + BRZ + M796
I’m assuming he fixed that problem unless it is normal to him to go on a spirited drive with two cylinders and a CEL.
Best guess based on the information: a bolt backed out or broke, hit the valve train then was shot out of the valve cover.
Drives: brz
I did the around and around thing. Built the engine then spun a bearing. Built the engine again and blew the transmission. Then the high pressure fuel rail popped loose, towed home again. Then I blew the head gasket. Some of it was my fault alot of was the huge turbos fault. It was fun while it lasted.
#9 | |
#10 | |
#11 |
Drives: brz
#12 |
Drives: Ft86
Any one knows what is the issued with 2013 FT86 model . after doing valve spring recall rocker arm came out from bank 1 . my engine is completely damage .
#13 | |
Drives: brz
2014+ has deeper pocket rockers, longer valves and different pivots(lifters). |
#14 |
Drives: Crapcan
Out of curiosity. In your experience, do you see a way to improperly assemble the head to where the car will run for a while and then have the rocker arm kick out? I don't see how it could be, just seems to be a sporadic failure in the early engines.
| Rocker arm broke and broke my valve cover... | j0hnnykthx | Issues | Warranty | Recalls / TSB | 9 | 08-07-2020 08:12 AM |
| Key Fob broke down | RichardsFRS | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 12-29-2015 04:38 PM |
| Broke my OFT, now what?!? | edeekeos | Software Tuning | 18 | 01-21-2015 02:12 AM |
| This is why I'm broke | cdrazic93 | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 07-26-2014 03:15 PM |
| I think I broke the tie rod....... | jshum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 06-04-2014 12:41 AM |
