Old 11-16-2019, 12:39 PM   #15
ls1ac
ls1ac's Avatar
Is there a change in sound with long right or left turns?
Still would not discount tires, try over inflating just for a test.
Old 11-16-2019, 01:06 PM   #16
sato
sato's Avatar
Drives: Dodge Patitas
If you also inspected tires and made no difference, it could very well be bearings going bad like others have said. I'm getting ready to replace my rear hubs @120k miles. Did the fronts at @80k.
Old 11-16-2019, 02:45 PM   #17
humfrz
This sort of thing...
Oh, "bushings" -
But how do bad bushings make a "humming" sound (with a car with an ICE)?
humfrz
Old 11-16-2019, 02:58 PM   #18
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh, "bushings" -
humfrz
Bushing deteriorate allowing components to move or vibrate leading to abnormal NVH. It's that 'chicken and egg' thing.. bearings fail leading to bushes to fail or bushes fail leading stress on the bearings..
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (11-17-2019)
Old 11-16-2019, 10:13 PM   #19
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
If it is front wheel bearings, you can determine location by "loading" one side. A sharp turn to the right will load the left side and vice versa for right. Sometimes if it's tough to determine location you can jack up the front. Put one hand on the coil spring and spin the wheel with your other hand. You may feel a vibration. If you do, that is the side with the bad wheel bearing.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
humfrz (11-17-2019)
Old 11-17-2019, 02:40 AM   #20
humfrz
really?
Old 11-17-2019, 03:09 AM   #21
JD001
JD001's Avatar
Drives: Subaru BRZ
really?
Look, I only drive the thng (occasionally) and read the Bible that is this Forum... I can make some more connections if you like.. ie tyres unevenly inflated or a driver that is unevenly knowledged or roads that are unevenly coated.. gosh there are so many 'chicken and egg' things that could wreak havoc.. poor bushes!!!
humfrz (11-17-2019)
Old 11-17-2019, 03:16 AM   #22
humfrz
OK,OK,OK - let's suggest to the OP that he replace the front wheel bearings and all the bushes. Then, if he still hears humming, we can conclude it's all in his head - a kind of tinnitus.
humfrz
JD001 (11-17-2019), kmbkk (11-17-2019)
Old 11-17-2019, 09:38 AM   #23
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
humfrz
Lol, it could be in my head. I’ve flown planes for over 18 years now (mostly prop) so who knows
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
humfrz (11-17-2019)
Old 11-17-2019, 11:30 AM   #24
gravitylover
Mine was rear wheel bearings. My assumption is it was the drivers side based on how it fell apart when I went to pull it but the insides looked surprisingly good compared to the noise it was making. There was just about NO movement in either wheel when it was off the ground and I wobbled it up and down but the noise in the car went from a low speed dependent rumble to an exceedingly annoying growl. FWIW with 127k on my 2013 the fronts still seem to be fine even though that's what more people have to replace first.
The Following User Says Thank You to gravitylover For This Useful Post:
Ultramaroon (11-17-2019)
Old 11-17-2019, 03:35 PM   #25
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 wheel bearings
Easy test for the front. Not so for the rear. Drive wheels are kind of a bitch. That being said, with a couple jack stands and a helper, it can be confirmed.
Spread the pads a touch.
Lift the wheel.
Spin it.
If you hear anything at all, the bearing is toast.
I've run mine in gear on jack stands. If you can't do pedal dance, weird shit will happen until it goes into limp mode. Especially in fifth gear the driveline is pretty quiet. I'm sure I'd hear a wheel bearing howl.
humfrz (11-17-2019)
Old 11-17-2019, 03:48 PM   #26
humfrz
Especially if they were crop dusters, spraying methyl parathion and stuff like that -
humfrz
Old 11-17-2019, 03:59 PM   #27
humfrz
OK, I got the picture.
Car falls off jack stands while running in 5th gear -
humfrz
Old 11-17-2019, 04:33 PM   #28
Ultramaroon
not playing cards
I guess I wasn't clear enough. The helper stays ready to step on the clutch.
Only an idiot would do otherwise. I guess while we're on the subject, don't fuck around gunning it either.
gravitylover (11-18-2019)
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 09:47 PM
Strange humming(ish?) sound coming from near rear wheels when car is off redwing634 Issues | Warranty | Recalls / TSB 2 04-02-2017 06:42 PM
AC Humming/Whining ericmpena Issues | Warranty | Recalls / TSB 2 06-08-2015 12:32 PM
Humming from front dphee79 Issues | Warranty | Recalls / TSB 3 04-24-2015 01:51 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 08:04 PM
