#15 |
Is there a change in sound with long right or left turns?
Still would not discount tires, try over inflating just for a test. |
#16 |
Drives: Dodge Patitas
If you also inspected tires and made no difference, it could very well be bearings going bad like others have said. I'm getting ready to replace my rear hubs @120k miles. Did the fronts at @80k.
#17 |
#18 |
Drives: Subaru BRZ
Bushing deteriorate allowing components to move or vibrate leading to abnormal NVH. It's that 'chicken and egg' thing.. bearings fail leading to bushes to fail or bushes fail leading stress on the bearings..
| The Following User Says Thank You to JD001 For This Useful Post: | humfrz (11-17-2019) |
#19 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
If it is front wheel bearings, you can determine location by "loading" one side. A sharp turn to the right will load the left side and vice versa for right. Sometimes if it's tough to determine location you can jack up the front. Put one hand on the coil spring and spin the wheel with your other hand. You may feel a vibration. If you do, that is the side with the bad wheel bearing.
Work Hard. Play Hard.
2016 Oceanic |
| The Following User Says Thank You to ActionMaxon For This Useful Post: | humfrz (11-17-2019) |
#20 |
really?
#21 |
Drives: Subaru BRZ
Look, I only drive the thng (occasionally) and read the Bible that is this Forum... I can make some more connections if you like.. ie tyres unevenly inflated or a driver that is unevenly knowledged or roads that are unevenly coated.. gosh there are so many 'chicken and egg' things that could wreak havoc.. poor bushes!!!
#22 | |
![]() humfrz |
#23 |
First 86 Driver Baby!
Drives: FR-S, Flex
Lol, it could be in my head. I’ve flown planes for over 18 years now (mostly prop) so who knows
| The Following User Says Thank You to kmbkk For This Useful Post: | humfrz (11-17-2019) |
#24 |
Mine was rear wheel bearings. My assumption is it was the drivers side based on how it fell apart when I went to pull it but the insides looked surprisingly good compared to the noise it was making. There was just about NO movement in either wheel when it was off the ground and I wobbled it up and down but the noise in the car went from a low speed dependent rumble to an exceedingly annoying growl. FWIW with 127k on my 2013 the fronts still seem to be fine even though that's what more people have to replace first.
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (11-17-2019) |
#25 |
+1 wheel bearings
Easy test for the front. Not so for the rear. Drive wheels are kind of a bitch. That being said, with a couple jack stands and a helper, it can be confirmed. Spread the pads a touch. Lift the wheel. Spin it. If you hear anything at all, the bearing is toast. I've run mine in gear on jack stands. If you can't do pedal dance, weird shit will happen until it goes into limp mode. Especially in fifth gear the driveline is pretty quiet. I'm sure I'd hear a wheel bearing howl.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (11-17-2019) |
#26 | |
![]() Especially if they were crop dusters, spraying methyl parathion and stuff like that - ![]() humfrz |
#27 | |
Car falls off jack stands while running in 5th gear - ![]() humfrz |
#28 |
I guess I wasn't clear enough. The helper stays ready to step on the clutch.
Only an idiot would do otherwise. I guess while we're on the subject, don't fuck around gunning it either.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (11-18-2019) |
| Fan static/humming noise | Zhangy | Issues | Warranty | Recalls / TSB | 8 | 08-26-2017 09:47 PM |
| Strange humming(ish?) sound coming from near rear wheels when car is off | redwing634 | Issues | Warranty | Recalls / TSB | 2 | 04-02-2017 06:42 PM |
| AC Humming/Whining | ericmpena | Issues | Warranty | Recalls / TSB | 2 | 06-08-2015 12:32 PM |
| Humming from front | dphee79 | Issues | Warranty | Recalls / TSB | 3 | 04-24-2015 01:51 PM |
| Buzzing/Humming sound at high idle | DGM.BRZ | Issues | Warranty | Recalls / TSB | 5 | 04-08-2015 08:04 PM |
