DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Master Collaborator
You can use this website: https://autoharnesshouse.com/ as a reference, and to also purchase different adapter harnesses as well as single pre-pinned wires to help you out with your install. |
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | ymshulman (08-17-2021) |
#16 | |
Drives: '17 BRZ
Thanks! Although oddly enough, those look different than the pins in the socket… This isn’t the kind of thing one can find at a hardware store, I take it? |
#17 |
Drives: '17 BRZ
Do the ground wires on the different ends of the DROK 12v-6v converter have to be connected to different ground points?
(I ask because I had almost enough pinned wires... If I can connect the ground wires without using the camera ground on pin 20 of the 28-pin, I can make do with what I have on hand.) ___ To clarify further - I have a harness from Joying, where all the ground wires it came pinned with, from all the various harnesses, all connect together. But the camera ground on pin 20 of the 28-pin was never connected. Can I either a) ground both ends of the DROK to the same place, or b) ground one end to this harness wire, and attach another to a chassis ground that I believe is somewhere in the cavity for the headunit? This would let me wire things up with what I can find in my toolbox. |
Tags |
dasaita, harness, headunit |
Installing a backup camera on a 2015 FRS? | PacManTheRS1.0 | Electronics | Audio | NAV | Infotainment | 7 | 05-03-2018 11:04 AM |
After installing backup camera, radio turns off randomly sometimes | VeganGirl | Electronics | Audio | NAV | Infotainment | 6 | 02-26-2017 10:47 AM |
My experience installing a backup camera | ARTBRZ | Electronics | Audio | NAV | Infotainment | 0 | 03-19-2015 08:37 AM |
Installing a Backup Camera on a Premium Bespoke Audio System | Ornelas66 | Electronics | Audio | NAV | Infotainment | 3 | 03-04-2015 04:33 PM |
Help installing backup camera / setting up AV on BeSpoke? | l0aded | Electronics | Audio | NAV | Infotainment | 11 | 07-18-2013 08:05 PM |
