Old 08-26-2019, 03:26 PM   #15
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by EndlessAzure View Post
I pulled both top and bottom pins, cleaned them, and put new OE rubber grease. Pins themselves looked okay. The lower rubber guide bushing was fraying, so I replaced it.
I think they are talking about the caliper piston boots.
Ordered some GT3 brake ducts to help with the cooling
Good call on the cooling, post up some pictures when you get it installed.
Your caliper piston boots looked alright to me, I don't see any serious cracking? @soundman98 What are the indicators that your piston will start to leak, I'm not seeing it and my piston boots look very similar.
DandoX is offline   Reply With Quote
Old 08-26-2019, 04:09 PM   #16
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Will do. It is certainly not an original idea, and it's not that involved. Just consists of basically plastic fins off a Porsche GT3 ziptied to the lower control arm.
My piston boots are quite brittle in some parts and crumbling =X. But as mentioned, I'm not too sure how that will necessarily lead to leaks other than the heat affecting the inner o-rings. The visible rubber boots serve mainly as dust covers
EndlessAzure is offline   Reply With Quote
Old 08-26-2019, 04:20 PM   #17
ls1ac
ls1ac's Avatar
Good call DandoX.
These pins need to move in and out to keep the pressure equal on both sides of the caliper, they have grease to lubricate and a boot to keep the grease in and the dirt out.
Having a slit and high temp will let the grease out.
The Following User Says Thank You to ls1ac For This Useful Post:
DandoX (08-26-2019)
Old 08-26-2019, 09:11 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
they're starting to crack. which is an indicator. what happens is that dirt/grime gets in there, and damages the internal piston seal or the piston surface. once either is damaged, the high pressure brake fluid finds a way out
DandoX (08-26-2019)
SOLD: FS 2004 STI Front Brembo Brake Caliper and more Kayysonie Brakes, Suspension, Chassis 11 06-19-2017 09:36 AM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
Darker front brake fluid EZBRZY Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 09-09-2015 06:55 PM
Front Brake Caliper Piston Rebuild? smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 10-17-2013 06:18 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
