#15 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Your caliper piston boots looked alright to me, I don't see any serious cracking? @soundman98 What are the indicators that your piston will start to leak, I'm not seeing it and my piston boots look very similar. |
#16 | |
Wheels for Brains
My piston boots are quite brittle in some parts and crumbling =X. But as mentioned, I'm not too sure how that will necessarily lead to leaks other than the heat affecting the inner o-rings. The visible rubber boots serve mainly as dust covers |
#17 |
Good call DandoX.
These pins need to move in and out to keep the pressure equal on both sides of the caliper, they have grease to lubricate and a boot to keep the grease in and the dirt out. Having a slit and high temp will let the grease out. |
| The Following User Says Thank You to ls1ac For This Useful Post: | DandoX (08-26-2019) |
#18 | |
ProCrastinationConsultant
| The Following User Says Thank You to soundman98 For This Useful Post: | DandoX (08-26-2019) |
| SOLD: FS 2004 STI Front Brembo Brake Caliper and more | Kayysonie | Brakes, Suspension, Chassis | 11 | 06-19-2017 08:36 AM |
| Stoptech S/S brake lines: same between stock caliper vs big brake kit? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-10-2016 07:14 PM |
| Darker front brake fluid | EZBRZY | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 09-09-2015 05:55 PM |
| Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
