Old 07-31-2019, 09:08 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
It would help to know what tires you're using and on which corner of the car they're mounted.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-31-2019, 09:35 PM   #16
frswildcat
Drives: 2013 Scion FRS
Wait a second. Did I misread when you said you got new tires? Did you put different tires on the front and rear? If so that can cause all sorts of weird stuff.
So yes I do but I did not have this problem under the same circumstances on my FRS. It has now been aligned and while the pulling has subsided it still wants to get squirrelly around a bend and the traction control goes nuts. All I know for sure is the I drove it for two months with the minor body damage on it and it handled fine. It wasn't until after it was fixed that I noticed problems. Issue now is that everything related to the suspension was confirmed fine by the shop so I am at a loss.
frswildcat is offline   Reply With Quote
Old 08-01-2019, 08:12 AM   #17
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
list the tires and their specs. Sounds like you could easily have traction control getting massively confused because the tires are different.
The Following User Says Thank You to why? For This Useful Post:
Tcoat (08-01-2019)
Old 08-01-2019, 08:15 AM   #18
why? (08-01-2019)
Old 08-01-2019, 08:21 AM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
1. What are your tire pressures?
Old 08-01-2019, 09:57 AM   #20
James H
Drives: 2017 BRZ
It can also be a worn out/faulty bushing or ball joint. I had that on my Accord a few year ago and the car acted really weird. It would wobble in mid corner when the suspension loaded up. Happened only on the side with the problem bushing. Do you have this happening to you when you turn in both directions?
James H is offline   Reply With Quote
Old 08-01-2019, 10:48 AM   #21
frswildcat
So just an update. The car just needed a break in period I think with the new tires. An alignment and 4 new tires has seemed to of fixed the problem.
The Following User Says Thank You to frswildcat For This Useful Post:
strat61caster (08-02-2019)
Old 08-01-2019, 10:51 AM   #22
Now you have 4 tires the same?
Dude you are confusing as hell to try to follow!
soundman98 (08-01-2019), Vital (08-01-2019)
Old 08-02-2019, 12:00 AM   #23
soundman98
ProCrastinationConsultant
soundman98's Avatar
update, new car fixed the problem. now onto the problematic wife
Old 08-03-2019, 11:28 AM   #24
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
That can’t be handled easily or cheaply.
Ernest72 is offline   Reply With Quote
Old 08-03-2019, 01:52 PM   #25
soundman98
soundman98's Avatar
it depends on a number of factors. but i know a guy at cement shoe factory...
handling, tires, traction loss
Found this Funny! Krazy Off-Topic Lounge [WARNING: NO POLITICS] 3 07-27-2015 08:30 PM
Funny aaguilar3 Off-Topic Lounge [WARNING: NO POLITICS] 0 12-12-2014 04:42 PM
FRS started funny N1rve Issues | Warranty | Recalls / TSB 23 06-04-2014 03:10 PM
Funny Pic whitefrs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-25-2012 10:32 PM
funny story fitcious Scion FR-S / Toyota 86 GT86 General Forum 18 09-05-2012 09:27 AM
